79 Cheyenne Dash Bezel Brushed Aluminum NEEDED
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueKnight, Feb 10, 2002.
  1. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    I'm looking for a 79 cheyenne brushed aluminum dash bezel. You know the thing that surrounds your gauges. Any how without a/c (no vents) would be preferrable. I have found a new one at LMC put they want to take me for a ride for one and this is just for a project im working on.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
  2. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Are you looking for the factory plastic with overlay or the aftermarket metal that LMC sells?
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  3. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    just the nice clean plastic bezel. I would hate to cut up the metal one
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i should have one on either of the two parts suburban's i have...???
  5. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    what do you want for them. They need to be realy clean and not well chipped at the screw holes or scratched up
  6. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Just for your info 78's had them also. Mine had one but I peeled it off due to the fact that it was craked around the screw holes. If any one else has this problem all I did was clean off the old glue and scufed the plastic with some 400 grit paper and sprayed it with some of that Dupli-color bedliner in a can it came out with a little rough look but it looked cool as a matter of fact I even remolded a corner that had broke off with body filler used some sand paper to shape it and once it was sprayed you could not tell the diffrence.
    Corey 78K5
    350CI, TH350, 203, Dana 44,12 Bolt, 4"lift, Shackel Flip, Sawsall and 35" BFG's
  7. reddog64
    Nov 9, 2000
    3,325
    I'll see if there anygood tomorrow... and post it here for you...
  8. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  9. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    yes but what about the cracked bolt holes on the sides. ?
  10. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    thank you very much
  11. BurbinOR
    5,829
    Oregon
  12. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    Actually I really looked at it today reall close and its in cleaner shape than I thought. Maybe the sticker kit will work. Although I can get Cheyenepickup.com catalog will not download.
  13. BurbinOR
    5,829
    Oregon
  14. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    Anyone come up with one of these?
  15. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    ttt
    </font color=blue>
    "If First you don't succeed, Destroy all attempts you've tried"
