79 front clip on 83 frame/body
Discussion in 'The Garage' started by gibby2268, Oct 18, 2006.
  1. gibby2268
    gibby2268 1/2 ton status
    Jun 6, 2006
    553
    Middle TN
    Recently acquired a 79 dirt cheap, had most of a long block in it, needs ALOT of body work on the rear (floors, driver's side rear quarter, doors, tailgate, rockers, basically EVERYTHING!:frown1: ) Anyway, I ran across a good 305 tbi and a donor car, dropped that motor in and just got it running, and was just beginning to think about diving in on the body when I ran across another 83 for cheap that had a good rear body just needs the front clip/motor. The front end of mine is the one thing thats pretty good so I was thinking of swapping the motor and front end over to the 83. So how hard is this gonna be? The 83 has nothing forward of the firewall other than the motor. I would also have to swap the streering column/box. Any advice is greatly appreciated!:bow:
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The 79 has a hood that goes all the way to the window , the 83 stops before the window with a panel between the hood and window .
    You need to cut holes in the 79 cowl for the hood hinges . the 83 has hinges on the cowl and linkage with coil spring on the hood .
  4. dyeager535
    26,975
    Not sure all of what the article covers, but I know the core support bushings changed between the years, and not sure how you'd work around the cowl issue.
    If you found an '83 truck good enough to buy, and cheap, I imagine if you keep your eyes open, an '81+ front clip shouldn't be too hard to find either.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you've got it mixed up Pauly. the '83 has the slots in the cowl, the '73-'80 hinges bolt to the fenders. remove '83 front clip, cowl panel, and wiper mech. install wiper mech from '79. then use '81+ core support bushings under the '79 core support and bolt the front clip on. install the hood, and you're done, your '83 now looks like a '79. headlight wiring may very well plug right into the firewall connector (my '82 did to a '79 clip)
    you may want to patch the slots for the hinges, as they are a direct opening to the vents in the kick panel.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The truck in my garage is 70's , and has the 80's hood hinges on it . They flopped around in the p/o's homemade hole . So I welded em tighter , burning the seals but its a truggy . I am going to use a skinned hood with through bolts on the 80's hinges .
    The hinges on the 77 in my garage look just like the hinges on my 83 . except for the weird homemade plasma type cutter holes .
    I am going to go home and look at the 78 in the backyard tonight (unmolested cowl ) and comapre it to my 83 ..... since I am going off memory , I didn't work on the truggy all blistering summer :wink1:
  7. gibby2268
    Jun 6, 2006
    553
    Middle TN
    Thanks guys, this is exactly the kind of stuff I was needing to know.:bow:
  8. sinner4
    sinner4 Registered Member
    Aug 4, 2005
    7
    Boise ID
    Was looking do the same thing, but on a 2 wheel drive 78' frame and a 83' sheetmetal. The frame has different measurements for the core support. I cant remember what the differences were.
    Not only the hood and cowl differences, the cabs are a little different, where the hood hinges are.
    The best and fastest, is the same years frame and sheet metal swap
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the hinge and spring on the 73-80s are one piece (i just took the hood off of my 77 the other day), where the 81+ have a separate hinge and spring, the hinge bolting to the cowl as previously mentioned, and the springs bolting to the fenders.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    here you can see the hinges, as they fit into the cowl on my 86.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    my 82, you can kind of see the spring bolted to the fender, and the hinge in the extended position (at the top of the pic, the triangular piece is the boot that goes around the slot that the hinge recesses into)
    i'll try to remember to snap some pics of the hinges on my 77 next time i have the hood off, if someone doesnt beat me to it.
