'79 Jimmy question????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5RON, Jun 17, 2001.
  1. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    \'79 Jimmy question????
    Scored a '79 GMC Jimmy 350/465/205 anyone know if the 350 is a 4 bolt? Aside from removing the pan, is there a way to tell? The body is a basket case and I'm taking the parts I want and trashing the rest! Anyone?
    Ron
  2. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Re: \'79 Jimmy question????
    Sorry, no way to tell without dropping the pan. Maybe from the casting # on the block but that is a shot in the dark at best.
    78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt w/ Detroit
    <A target="_blank" HREF=http://www.bowtiecrawler.com>http://www.bowtiecrawler.com</A>
  3. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    If you look at the machined surface in front of the passenger side head there will be numbers stamped there. Make a note of these. There are also numbers cast in at the rear of the block on the drivers side just in front of the bellhousing. Jot these down too. Then do a search on GM casting numbers and compare your numbers to the lists on one of the multiple sites that have them, and presto chango, you'll have the stats for your motor, and know if it's original.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  4. K5RON
    Apr 14, 2001
    219
    X,
    Thanks for the reply. The engine, xfer case and tranny are pulled. Just wonderin' if it's a four bolt. Prolly won't rebuild it for some time.
    Thanks,
    Ron
  5. K5RON
    Apr 14, 2001
    219
    CV,
    Thanks. Will check the casting numbers. Spent all day in the garage pulling the motor and such. Is there a web site for the casting numbers?? I'll check under the grease tomorrow! Or do you mean to search C/K5?
    Ron
  6. mlb79
    mlb79 Registered Member
    May 24, 2001
    40
    evansville, IN
    Check out www.mortec.com or www.nastyz28.com. The z28 site requires a little digging through the site but worth the effort. Mortec has a great listing of casting numbers.
    Mark
    79 K5, 3" lift, 400 cubes of nasty
  7. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    a really long time ago, i think someone told me that all truck motors were 4 bolts. but i am not sure if that is true.
    Knife.
    knife.coloradok5.com
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I think 2 and 4 bolt were used in trucks. Certainly i've never seen a 305 with 4 bolt mains although they were used extensively in trucks. The best way is to remove the pan and look. If the motor is not being used and will be built then removing the pan shouldn't be a big deal. Take it off and have a look.
    Rene
