????? 79 k20 14 bolt will it fit ??????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Aug 28, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I went to the salvage yard today and found a 14bolt that looks like it will fit but I don’t know. What I did was measure from spring pad to spring pad on the axle that’s on the K5 now. The measurement was about 45”. I say about because I had to move it over the diff cover. Looked at and measured about 25 14bolts that look good but did not meet the measurements of mine. I finally found one that had the same measurements as mine, 45”. The axle’s diff cover had “79 Chevy k20 written on it and had a tag with the same thing, but also had 4.56 too. Will that axle bolt right in?
    Thanks,
    Charles
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It should. Any 14 bolt out of a 3/4 ton should work. Not the 1 ton. 4.56 gears? You dog!
  3. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    why wont the one ton work? i always thought that they were the same length. I also thought that 14 bolts only came stock with 4.10 and 3.73. did someone put those 4.89s in it afterwards?
  4. spaceboy
    spaceboy 1/2 ton status
    Jan 14, 2002
    106
    Pearl City, Hawaii
    A 3/4 ton 14FF will bolt right in. One ton spring perches have to be moved. As for the gears my D60/14FF came with 4.56s.
  5. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Thats what I though but, I was unsure which model was the 3/4 ton. Is the K20 3/4 ton?
    Charles
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    The one tons had a narrower frame. You can move the perches and it will work fine. You could get 4.56's not common. Military rigs I think most had 4.56's
  7. 83PJW
    Aug 18, 2002
    160
    leavenworth, ks
    holy pooh learn something new every day. what about a dana 60 front is it a direct bolt on or do i have to move the perches then too?
  8. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Sandman, there were many 14blts there that had the perches futher out. I thought those were the 1 ton. The one I found was the only one that had the perches that close.
    Charles
  9. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I will go measure mine right now. Hang on...
  10. 83PJW
    Aug 18, 2002
    160
    leavenworth, ks
    the big wide 14 ff are from a van. if thats what you are refering to.
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Ok, My blazer with 14 bolt rear measures about 43" from spring center to spring center. I got my axles off of an '84 1 ton and had to trade in the rear because both perches were like a 1 1/2" to narrow. Hope this helps.
  12. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    I had a feeling thats what they were....man, they were huge!
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    The Dana 60 front is a bolt in. No problems there.
  14. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Yes Sir, that helps out a great deal. Now, I'm sure they will fit. Thanks for the help
    Charles
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    My 14b came from a 77 3/4 ton...Bolt in except for the shock mounts. They hung to low for the shocks to reach. Had to cut them off and re weld them higher up on the tube. Simple though, about 15 minutes for each one. /forums/images/icons/grin.gif
    Picture here...
    And here...
  16. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Hey Sandman
    Not to split hairs or anything but so you know.
    The one ton frames arent narrower, the spring hangers are.
  17. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You are correct, and thanks for pointing that out. I know some people get upset about being corrected but I would rather cut down on the number of times that I look dumb. /forums/images/icons/smile.gif
