79 K5 about to get 4" lift w/35" tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gaine7, Apr 5, 2001.
  1. gaine7
    gaine7 Registered Member
    Apr 5, 2001
    23
    Clemson, SC
    79 K5 about to get 4\" lift w/35\" tires
    I was wondering if the driveshaft is going to work correctly after I install a Pro-Comp 4" suspension lift and 35" Pro Comp MTs? I read the earlier posts about the lift and the great tips on being prepared. That helped but I am nervous about what problems I am going to run into after the lift is done.
    How many more insects would there be if there were no cars to hit them?
    Jim Gaine 1979 K5 Cheyenne Small Block 400 - bone stock (not for long)
  2. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    Re: 79 K5 about to get 4\" lift w/35\" tires
    you should be fine...that is if you plan on only street driving. If you want to do some trails then you better plan on going with 6" or for a 4" needing some fender trim.
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Your d-shafts should be fine with a 4" lift.
    But like Lehtola said, you may rub alot while offroad..
    <font color=green><A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A></font color=green>[​IMG]
