79k5 canister and fuel line question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, Aug 4, 2005.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    There is a large metal fuel line that runs infront of the engine on the crossmember traveling just above the brake line splitter. It then goes to a rubber line near the steering gear and to a plastic canister on the raditor support. There are few rubber lines from the canister to the carb.
    An employee of mine crimped the metal line installing a ord steering box brace.
    Is this line a return? Just wondering if it was under pressure or if we could cut it and route it around the brace with a rubber patch.
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    that sounds like the EVAP line to the fuel tank from the EVAP canister. You should be able to patch it up with some rubber line and be okay...
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if its 3/8" then i bet it used ot run up and T with the PVC hose
    if you clean off top of the evap can yo will see there are short words for each port, one will say PVC and another will say MAN and others will say something else
    you can figure it out from looking on the evap top
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    It was the line to the fuel tank. I spliced in some fuel hose, but can I ditch this entire canister setup and delete all the hoses. How to??
  5. dyeager535
    26,982
    191
    Problem is, EVAP is the vent for the tank on the later setups. Hard to vent the setup without introducing another way for (humid) air to get in the tank and form condensation.
