8-12" and front driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 98sub454, Jan 24, 2003.
  1. 98sub454
    98sub454 Registered Member
    Jul 18, 2002
    74
    La Habra, CA
    8-12\" and front driveshaft
    I am about to go buy a 74 K5 and i want to get a lift somewhere in the range of 8-12" My main question is, do you need an aftermarket driveshaft for this? Also no matter how high i go i will be running a superlift.
    Also it will mainly be a mud and sand truck, and i wanted to run at least a 40" tire, maybe more, if i did the 8" how well, or would they even clear? would i need cutouts or should i just go higher. thanks
    /forums/images/graemlins/k5.gif /forums/images/graemlins/burb.gif
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Re: 8-12\" and front driveshaft
    Yes, you will need aftermarket shafts, or have yours lengthed, both front and rear. AFA amount of lift, I have seen guys running 38's on 2 1/2" of lift and some serious fender trimming. The amount of lift you'll need will depend on whether you are willing to take a sawzall to your rig or not... I run 38's with 7" of lift and no trimming. If I were to run 40's then I'd probably have to run at least 10"-12" of lift if I didn't want to trim my fenders.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It can start to get expensive after 6" of lift. You will defiantly need a custom driveline in the front. You might want to consider a body lift at the same time and also cutting the fenders some to make the lift part easier. I run 40's with a 6" lift, 3" body lift, cut fenders and moved the axle forward. In the mud and the sand I think I could fit 44's. /forums/images/graemlins/grin.gif
  4. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    yeah if i do trimming i will most likely use the bushwacker flares or something like that.
    so would i be better off just getting a 6+3 and then the flares to clear 40s?
  5. Ryan2286
    Ryan2286 Registered Member
    Nov 7, 2002
    32
    South Suburbs of Chicago
    I'd say no, on the 6+3. Everyones running that. your driveshafts are getting a little short at six inches any way and so are your brake lines and you will for sure need steering modifications. So why not do it the way you want to right away. If you have nice fenders and want to keep them lift it high enough so the rubber won't rub. I would say run either an eight inch lift with springs in front shackle flip and springs rear and a 2 inch body. Or go to a ten right away and run 44's and see if you need to get the body higher. Either way get a dropped drag link and raised steering arm and brake lines and of course driveshafts.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    It all depends on what you want I suppose. I wanted to keep a somewhat flexy suspension so I capped it at a 6" lift. I still ran the 40's but they would hit the firewall now and then. So I put on the body lift and moved the axle. You can go as high as you want if you have the cash.
  7. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    You'd probably end up doing some minor trimming for flex-while-turning.
    You can run the stock front driveshaft if you modify it so it'll flex more (time to get out the die grinder). I suggest keeping a spare driveshaft with you. That's what most guys on a budget seem to do. It's probably what I'll end up doing. Not everyone can pay for overpriced driveshafts.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Superlift SUCKS.
    last I heard the springs are now made in India.
    when I bought them they were made in CANADA.
    the front springs are too short.
    the reason they designed them that way is to use the stock short shackles.
    they should have just included shackles that were the correct length and built springs properly as the resultant angle on the front shackles is terrible.
    pretty much the cheapest springs you can get.
  9. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    YEP my 12" front superlift's where made in india.
    dave
  10. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    ok so what lift would you guys reccomend in the 6" to 10" range?
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    If your looking for soft go with the Tuff Country. They only go up to 6" though. Syjacker builds a decent 8" spring. After that I would have said superlift but now I'm not so sure.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think custom lifts are the only way to go.
    I think some lift springs from another application and move the hangers would get you there.
    a 48" long spring just doesnt have the length to work well with that much lift IMO.
    I would bug tRusty or anyone else on here to see what his thoughts are on using some ford 57" long springs in the front of a chev to see if a set of 6-8" ones would raise a chev that high.
    more work but the results will be more what you want in the long term.
    if you decide to run the superlifts I would disassemble the pack and remove the shortest leaf and drill the tips of all the leaves for plastic wear pads before I bolted them to the truck
    add shackles that are at least 3/4" longer then stock(any lift springs need this"
  13. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Put a crowbar in your wallet and buy some Nationals!! /forums/images/graemlins/thumb.gif
  14. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    haha, the crowbar has already been there, thats how im gettin the truck in the first place.
    i need something else to beat up on since i dont want to destroy my sub and i want a nice big mud truck.
    the more i look into it the more i am leaning towards a 6" and then a body lift later. then just hack up the fenders if i need to. it would be really nice to have a truck on 44s though /forums/images/graemlins/thumb.gif
    for now it looks like im gonna get a 6" and some 36" hummer tires on some black (most likely fake) beadlock wheels. what do you guys think?
  15. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    did you ever think about axle's? /forums/images/graemlins/pimp1.gif
  16. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    yes, those will come as these break, its not a daily driver so im not in that big of a hurry for anything like that yet. if i come across a deal i will pick up a 14 bolt and d60.
  17. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    ok i did a little more research and now im pretty set on an 8"
    so i am basically back to my original question, can i just lengthen the driveshafts or do i need a high angle shaft for the front and rear?
    also how do you guys feel about the lift shackles from hill 4 wheel drive?
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    8" makes for ugly front driveshaft angles
    the joint at the dif will want to spit out under load.
    axle wrap will add to the problem.
    you can carry spare shafts or spend the $$ to get the front axle turned.
    High Angle driveshafts will do nothing to alleviate the front shaft problems at the dif end IMO as the shaft isnt the problem
  19. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    I've got 8 in. skyjacker springs in front. you will need a high clearance shaft for front and a c.v. shaft for the rear to keep the angles in check. i wouldn't use the hill shackles with the 8's, your front shaft will never tolerate the angles unless you went to a doubler to bring the angles back in place or you went with a h.p.60. i like the 8's nice ride and very good flex for an 8 in. spring besides now i have more room when i upgrade to 44's this spring. /forums/images/graemlins/grin.gif
