8 axle bolts for 14ff. wierd huh?? HELP!!
Discussion in 'Parts & Trucks Wanted' started by camarossguy2, Jun 7, 2005.
  1. camarossguy2
    camarossguy2 1/2 ton status
    Aug 10, 2004
    214
    ABQ NM
    I bought an 14 bolt ff axle missing a shaft and the bolts the hold the shaft on. Now i got the shafts but dont have the bolts for that side.
    Dealer here cant get them for a resonable price, none at the junk yard, so just hopin i could get some help.
    Anyone readin this next time you go to the junk yard, could you knock off 8 for me?
    :edit:
    Got some. there was an illegally parked out of state van infront of work today. Now its an illegally parked van with 8 less axle bolts :D
    Double checked, bolts from hardware stores with shoulders do not have a large enough OD to hold the axle correctly. the factory bolts shoulder is noticebly larger.
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I think there was a post about this a few days ago, and if I remember right they're just 9/16 grade 8 bolts. :xmas: If I'm wrong I'm sure someone will correct me.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You can pull one off of the other side and bring it into a hardware store and match it up to the closest grade 8 bolt you can find, then buy 8 of them.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    They are just 1/2" Grade 8 bolts. :)
  5. 85Blazer
    85Blazer Registered Member
    Feb 25, 2000
    30
    Dunkirk, MD
    I have some I'll give you. Just pay the shipping. PM me.
  6. camarossguy2
    Aug 10, 2004
    214
    ABQ NM
    I went to do that but i dont think it will work
    Sure the bolts will thread and tighten, but the "shoulder" is different, even from shouldered bolts from the hardware store.
    Look at the bolts for the axel, they have a very thick shoulder. Its OD if = to the ID of the axle shaft holes. with out it being so tight the axle would be able to rotate som. The bolts from the hardware store, the shoulder's OD was a couple thousands smaller then the stock bolts. thats why i was looking for stock bolts.
    Hope i didn't confuse anyway, but see what im saying?
  7. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    contact these guys...
    http://www.vancouverbolt.com/
    measure everything about the bolt before you do. If its known to man, they have it or can get it.
    j
  8. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    This is true. If all else fails and you can't get any from here or the 'yard, just mix and match. Use 4 OEM and 4 hardware store bolts per side. 4 bolts with the proper shoulder should be enough to locate the axle.
  9. camarossguy2
    Aug 10, 2004
    214
    ABQ NM
    Well right now i have 4 in each side, nothing in the others. Im sure 4 are plenty srong enough for a stupid TBI, but i will get the rest soon....guess i will just keep checkin in to the junkyard... (btw fords and dodge dont fit)
