8 bolt vs 12 bolt Hummer wheels
Discussion in 'The Garage' started by bigbluesuburban, Dec 14, 2006.
  1. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    Which is better and why?
    Other than the obvious 4 extra bolts, which I see as a great selling point cause more is better. Is there a strength/durability issue with the 8 bolt rims?
    School me... please
  2. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    The 8 bolt is rated for bias ply tires. The rim material little thinner and does not have a DOT stamp.
    The 12 Bolt is designed for Radial tires and higher pressure. The rim material is thicker and it should have the DOT stamp.
    I am going to run the 12 bolt since I have 5 new ones that just need to be recentered.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    8 bolts do have a DOT stamp.
    Rated for 30 PSI
    12 bolts re good to I believe 65 PSI
  4. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    The 12 bolt rims come apart differently than the 8 bolts and yes the 8 bolts do have a dot stamp, I know I have recentered 8 bolts. I have never had a problem with mine and they seem to be more common so I say go with what you can get at a better price. I dont believe that the 12 bolts are any thicker and yes they are rated for higher pressure but unless you plan on putting them under a really really heavy truck I dont see the need. I'm running mine with a fully loaded down blazer on 38.5'' swampers.
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I think when you get down to it, about the only thing better on the 12 bolts are the 4 extra bolts. I don't know anything about them being thicker than 8 bolts. I highly doubt it, at least not anything substantial. But, being a little more popular, they usually go for a bit more. I can get 8 bolts all day, with a tire for 30 bucks each. So, when I chose to go with H1's for cheap double beadlocks, I saved enough going with the 8 bolts, to add upgrades in with my recentering, and still come out way cheaper than any other beadlock.
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    I had read that the only reason they armed forces switch to 12 bolts, was the manual for chaging a tire read to remove the 8 lug nuts, and people would try and remove the rim bolts so they switch to 12 :dunno:
  7. bigbluesuburban
    Feb 8, 2006
    1,362
    Having been in the USMC as a Motor T Mech and having watched 1st echelon drivers do maintenance... This would not suprise me at all.
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Semper Fi....lol
  9. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    thats what i tell people and they all beleve it and shake there heads at you yanks LOL
    ah don't feel bad, ever hurd of an iltis? :doah:
  10. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    NO FORKING WAY :laugh: :laugh: :haha: :haha: !!
  11. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    After several years running recovery in my field artillary unit, I can tell you that on several occassions I would have to come out and pick up hummers for just that reason. I'd say at least a half dozen times I had to pick up a vehicle because some idiot broke the wheel down trying to take it off the vehicle.
  12. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    If there were 2 sets and they were the same price, id take the 12's over 8's. If the 12's were anymore, id take the 8's. Theres absolutley nothing wrong with em.
  13. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I bought my 8 bolts for 35 with almost brand new tires. Actually a couple still had the rubber tits on the tread, and all the tires were still soft and plyable. I could have paid 30 for some with a lot less tread. But on 12's with "fair" (maybe about 50%) tread, the price was 100.00 each. 60.00 each without any tire at all. So, usually, it's double or more for the 12's. More than enough to steer me towards the 8 bolts. Yeah, I would have gotten the 12's if the price was the same, but it's always much more.
  14. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    i talked to dealer tire her ein phx,
    asked the differerance.
    he said the military switched from 8 to 12 bolts do to the 8 bolts leaking when the vehicle is heavily loaded, he also said due to the change over is why 8 bolts are available and the 12 bolts are harder to find since they are still in use.
    this is what he said he heard
    he also mention that they had changed tires to a higher load range, but now have alot of sidewall failures
  15. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    does any body have pics of the two of em??
  16. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,545
    1,462
    the armpit of the east coast, 08046
    here's a set of the 8 bolts i have.
  17. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    The 8 bolts are for a bias ply tire. The 12 bolts have a radial tire. Maximum tire pressure is 35lbs and 50lbs respectively.
  18. blasphemous
    blasphemous 1/2 ton status
    Jan 11, 2007
    457
    Louisville, KY
    Why do the Hummer wheels have to be recentered? Are they a double bead lock "out of the box" or do they need to be modified?
  19. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    see the rim in the pic the face of the rim is even with the out side of the tire, this means the is over 7" of back spaceing.
    so they can be run on a dully set up no problem, but for every thing elce the centers must to cut out and a new one welded in, hence the expence
  20. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    One more question... how much does recentering cost? /hijack off
