8 inch lift question
Discussion in '1936-Present Suburban' started by 85burbanator, Jun 17, 2003.
  1. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    ok ive posted this in some other forums here already but i figured i might as well post it here to. im going to do an 8 inch lift to the burb. i have most of it figured out and every thing but i was concerned with the drive shaft lengths and angles. i know ill prolly need new ones so what do you guys recomend and how do i measure them correctly? also how do i drop the t case and how much should i drop it? any info is apprecieated. thanx
    mike
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    This is just my $.02, but if your going with an 8" lift, i wouldn't bother with lowering the t-case, it just makes the front shaft angle worse, just get a angle finder and measure your angle, then get some high angle shaft's and be done with it /forums/images/graemlins/thumb.gif
  3. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    yea i wasnt sure about the tcase drop. it was just suggested buy my uncle. were can i get an angle finder or what ever it is.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Any hardware store...
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Here's an angle finder that you can pick up at any Sears store: Angle Finder /forums/images/graemlins/cool.gif
  6. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    so would i find the angle after or before i lift it? im thinking after but then that means ill be without my truck longer.
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep, only way that i know of is after is lifted, otherwise you won't have anything to get the correct angle off of.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  9. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    yea thats what i figured after i posted it. what drive shaft company would you recomend.
  10. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
