8 inch lift questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85burbanator, Feb 17, 2003.
  1. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    hey there i think this is my first post so i figured i would ask a question. im looking for an 8 inch lift kit and cant decide between superlift, skyjacker, or the bds kit. some people over at ps.com said alot of yall run the bds kits. how are they? im not looking for rock crawling flexibility but some flexibilty would be nice.
    also how is the ride compared to superlifts and skyjackers lifts? oh yea, this is for my 1985 gmc suburban k1500. any info would be very much aprecieated also maybe some pics of an 8 inch lift on 35's on an older k5 or burban or something of that sort so i can get a good idea of what she'll look like. again i thank you.
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i used to run 8 inch superlift springs, and those SOB's were stiff as hell, I think i would go with skyjacker softrides, I think that the burb in TTC 2001 was running 8 inch skyjackers,
  3. NE-RokToy
    NE-RokToy Registered Member
    Dec 24, 2002
    39
    Omaha NE
    if your worried about ride and flexability I would be looking at something smaller then an 8" lift. To each his own though
  4. MR4WD
    MR4WD 1/2 ton status
    Jul 28, 2002
    133
    Fort McMurray, Alberta.
    I used 8" softride leafs on this truck, with a front mounts dropped 3" and the rear shackle 1.5" longer, the spring still touches the frame under max compression. In the rear, I used a 4" shackle flip, 4x56" spring and a 4" block welded to the diff. 44" bogs on 15x14 bead locks.
    Apparently I need more room in the front, since the tires regularly clearance the fenders.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If your only looking for 8" lift total, you may want to consitter 6" lift springs up front, 4" shackle flip with 2.5" springs in the rear, and a 2" body lift. I personally like BDS, but alot of people like the Tough Country springs. If you're only running 35" tires, 6" lift should be enough, or 4" and some fender trimming.
  6. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    8" will tower over 35s /forums/images/graemlins/wink.gif
  7. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    i know but that is only till i can afford 37's or 38's.
