8 inch lift rear diff angle ?
Discussion in 'The Garage' started by dheavychevy38, Sep 22, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    what degree shim are most of you running in the rear of your k5's with 8 inch suspension lifts????
    I took my lift off my fullsize pickup and it doesn't seem to be a good angle for a k5
  2. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    does anyone run a welded 10 bolt ?
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    It's TWO, TWO, TWO posts in one! /forums/images/graemlins/grin.gif
    The shims tend to be real specific to the truck, there's so many combinations of transfer cases and t-cases with different kinds of outputs etc that there is no one magic answer. Figure out what your angles are on the t-case output and the axle yoke, that will tell you what angle shim you need, if any.
    Welded 10 bolts are bad juju, they break often enough when they're open. This is especially true for you if you're running tires big enough to warrant 8 inches of lift./forums/images/graemlins/crazy.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I definitely wouldn't weld a rear 10 bolt. If the shaft breaks you could die, something about that wouldn't want me to weaken the axle.
    Front? Why not. As long as you don't mind not being able to steer, it might not be that bad.
