8" lift and front driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CarolinaBogger, Nov 29, 2001.
  1. CarolinaBogger
    CarolinaBogger Registered Member
    Apr 17, 2000
    86
    Boone, NC
    8\" lift and front driveshaft
    For those of you who have an 8" lift, will a driveshaft spacer be enough to correct the difference? I was going to order a Superlift spacer but if the driveshaft will still be too short with the spacer, then i will just get the shaft lenghtened. Thanks ya'll
    "I'm old enough to know better, but I'm still to young to care!"
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Re: 8\" lift and front driveshaft
    I think flcpl4fn has a spacer in his Jimmy w/ 8 in. springs. I am not sure if it was enuff or not. If I can catch him online Ill ask, or tell him about this post and he can answer.
    If ya can't stop.......Smile as you go under! [​IMG]
    PIC of mine from flblazers site<a target="_blank" href=http://www.flblazer.alloffroad.com/photo3.html>
    GO</a>
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would bet money it'd be too short.
    Tim
  4. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    heres my problem, the driveshaft will almost fit, however, in full droop the axle is too low and the driveshaft will hit the xmember. will this spacer help any? and yes my tcase is dropped, i just realized that the previous owner did this for his 4in lift, dont know why but he did.
    phill
    <P ID="edit"><FONT class="small">Edited by shupach on 11/29/01 08:04 PM.</FONT></P>
  5. CarolinaBogger
    Apr 17, 2000
    86
    Boone, NC
    SHUPACH, so do you have an 8" lift? And if so, your stock front d/s works?
  6. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Re: 8
    When you drop the case for a better angle to the rear you will slightly raise the front. The spacer will move the joint further out towards the front and will help w/ clearing the X-member some.
    GO</a>
  7. shupach
    Dec 28, 2000
    648
    Dallas, TX
    yes, i just installed it, i however dont have the spacer kit which i need, but ya the driveshaft is almost perfect its off by like an 1inch or 2 at most. ill try to get some pics if u want
    phill
  8. CarolinaBogger
    Apr 17, 2000
    86
    Boone, NC
    pics would be great! Thanks for the tips
    CB
    <font color=green>"I'm old enough to know better, but I'm still to young to care!"</font color=green>
  9. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    I have an 8" Superlift on my '75 Jimmy and the stock drive shaft was long enough to bolt up but only has another 1/2" of extension left.
  10. CarolinaBogger
    Apr 17, 2000
    86
    Boone, NC
    Well, I just ordered a Superlift spacer kit from 4wpw. It was about $49, so not too bad. Hopefully that will be all i need for the time being.
  11. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    A DRIVESHAFT SPACER!! I never heard of a thing. I want to lift my blazer at least to 4" but maybe 6". Would I be able to use my stock driveshaft? (87 blazer) It's currently at 2" susp. lift and 3" body lift.
  12. 87superblaze
    Mar 12, 2001
    104
    Upper Michigan
    It's the front driveshaft I am worried about. I already have the proper rear driveshaft.
  13. CarolinaBogger
    Apr 17, 2000
    86
    Boone, NC
    Well, thats what i getting ready to find out when i get my kit in. My ft d/s worked fine with my 4"lift. If this kit doesn't correct it enough, then i'm just gonna return the spacer and extend my d/s
  14. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    the driveshaft spacer bolts on the flange from the front of the t-case...it gives about and inch or so of space...it worked ok for me but i dont have a lot of room to stretch it out now...
    Later
    Have you driven OVER a Ford lately?
