8 " lift driveshafts
Discussion in 'The Garage' started by dieselburban, Mar 9, 2004.
  1. dieselburban
    dieselburban Registered Member
    Jan 5, 2003
    21
    OWATONNA,MN
    8 \" lift driveshafts
    I plan on putting in a 8" suspension lift do I need to lenghten the shafts or put some sort of spacer in? front and rear.posted this before but didnt get any info,on a 84 suburban 1/2 ton. if any one else did a 8" susp lift give some info on everything that you did please and thanks... /forums/images/graemlins/burb.gif
  2. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Re: 8 \" lift driveshafts
    on my 1/2 ton 86 fullsize long bed had to get the rear shaft longer and the front also
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your front shaft will need to be longer.
    In addition, you will need to grind your CV like crazy to keep it from binding and turn your pinion angle up to minimize the angle.
    Or, save your pennies for a while like I'm going to do and go with a high angle CV shaft with a big joint on the front part.
  4. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Make shure the drive shaft is lengthen right. My front was not lengthen right and it bodomed out against its self and broke my t-case in half last weekend
  5. dieselburban
    Jan 5, 2003
    21
    OWATONNA,MN
    Ouch that sucks,how much should I lenghten them if the pinions were pointed at the transfer case? /forums/images/graemlins/dunno.gif
  6. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I had 8" and the front driveshaft had to be lengthened and the rear did not have to be.
  7. dieselburban
    Jan 5, 2003
    21
    OWATONNA,MN
    Also will the front shaft clear the crossmember?
  8. funkycold
    Apr 22, 2002
    435
    Orange County, CA
    Mine cleared. But you may have to do something with the exhaust pipe if you have single exhaust.
