8" lift / Front Drive line angles????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CarsonRoen, Apr 27, 2001.
  1. CarsonRoen
    CarsonRoen Registered Member
    Mar 7, 2000
    16
    WA, USA
    8\" lift / Front Drive line angles????
    i have a 73 Jimmy and some guys down at the diff shop say that i need to have my whole front end machined so tehy can rotate the diff up. I did not think that was a good idea, what do you guys do about the front driveline angle???? do you just add much shimming? help please before i spend thousands of dollars.
  2. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Re: 8\" lift / Front Drive line angles????
    Well Carson that can present quite a problem with 8" of lift. GM front ends require about 5-7 degrees positive caster to steer stright and not wander. Adding front shims to kick up the front pinion to lesson the front driveline angle only adds more positive caster angle wich worsens steering. To be done properly and restore original caster angle, your front axle tubes need to be pressed out and the pioion rotated up the proper amount to releive driveline angle and restors proper caster angle. I had Dynatrac perform this on my D60 with 6"of lift. It cost about 600.00 . Some people have the nuckles cut, turned, and rewelded. Dynatrac advises against this procedure. Hope this helps.
    MAC
