8" lift, good or bad
Discussion in 'The Garage' started by purple76pearl, Jan 14, 2003.
  1. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    8\" lift, good or bad
    i just got a 75 chevy 3/4 ton 14bff rear, dana 44 up front, thinking about super lifts 8" lift for it and some 40 inch boggers. what problems are there out ther ewith the 8 inch lift, and what advantages does it have from the 10" if any, any suggestions would be appreciated /forums/images/graemlins/k5.gif
  2. hardcore_rob
    hardcore_rob 1/2 ton status
    Dec 6, 2002
    111
    Colorado Springs, Colorado
    Re: 8\" lift, good or bad
    not really an answer for ya , but oh man , i only have a 3 inch lift, gonna run 33's or 35's soon, cant imagine how large your truck is with an 8 inch lift and 40's, got any pics...
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I take it you're into mudding. 8" and 10" probley won't have a whole lot of flex. But for mudding, you won't need alot of flex. If you're into rock crawling, you'll want the flex.
  4. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    I run an 8 inch superlift on my k10 The ride is a little stiffer than my 4-inch rancho I had before I have a 12 inch superlift on my k20 it rides rough but I don't mind I would go with the 10 inch that way you could clear 44" tires later on cause if your like me 40"s just won't be big enough Good luck /forums/images/graemlins/truck.gif
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Driveline angles might be a little better to deal with. I had 40"s on a 6" lift for a while.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Here are some pics of mine. 6" lift, 3" body, cut fenders, Moved the axle forward, and the front is a D60.
  7. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    I had A 6inch superlift and 40" tsl on my K20 worked very good but the tires got in the fenders when I would play in the rocks so I put the body lift on then It worked great /forums/images/graemlins/truck.gif
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    My tires would hit the firewall. So I tried the body lift and they still hit the firewall. Moved the axle forward and now theres Gobs of room.
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Your major concern will be the driveline angles. Who said 9" of lift can't flex?
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I like it! /forums/images/graemlins/thumb.gif
  11. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    my fenders have alittle bigger openings than yours I took the sawzall and hammer to the corners of my fenders /forums/images/graemlins/truck.gif
  12. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Does anyone have a profile shot of a 8" lift and 40's? or 38's?
  13. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    here's a very very old picture of mine with 39.5s and 8"
  14. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Perfect Thanks /forums/images/graemlins/thumb.gif
  15. BOWTIE
    Dec 28, 2000
    2,018
    another shot of an 8" lifted* rig flexing. /forums/images/graemlins/shocked.gif
    *8" skyjacker springs with the bottom leaf removed.
  16. purple76pearl
    Jan 13, 2003
    450
    missouri
    ok you have all been alot of help, ill take all that in to prespective when i start on that one, but back to my baby the 76, i want it to flex like the one above this, and the other one with 9" lift, some one help me, what do i have to do to get that kinda flex out of my 6 inch lift, and i still havent foudn out how much i have to extend my drive shafts with 6 inch lift, and while im going, how exactly do i move my axle fowards i want to run 38's with no more lift, is that possible, i ask alot of questions i know /forums/images/graemlins/k5.gif /forums/images/graemlins/ears.gif
  17. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    hey jeremy,
    not quite a profile but heres a pic of mine on 39s...its 8" front packs and 6" rears
    i got a little height out of the 14 bolt in the rear though
    webshits picture
    Later
  18. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    8" all the way around will clear 39s if you are driving straight on the highway...if you do any lock to lock turning, depending on your backspacing of course, you will most likely rub if you are running something wide like boggers...check my previous reply to 55willy and i have a pic of mine with 39s on it with 8" in the front.
    Since then I went to 42s and now im going to 44s and im redoing all my suspension...if I were you id go with 10" now just to compensate for larger tires later
    Later
  19. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    6" suspension lift + fender trimming, and mayby a body lift should clear 38's with no problem.
  20. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    If you don't mind trimming the fenders and moving the front axle forward, you can clear 44 with 8". I currently have 8" front springs with Atron 8 degree offset wedges, 56" rear leaves with a shackle flip and 4" blocks. It flexes great, especially in the rear and hasn't rubbed yet. If you are looking more towards mud, go with the 10" kit. I highly reccomend crossover steering too. Also, if you are running a 465/205 combo, you might have trouble with the front driveshaft with either one.
