8" lift on '82 Blazer
Discussion in 'The Garage' started by jwallace1029, Dec 28, 2006.
  1. jwallace1029
    jwallace1029 Registered Member
    Dec 7, 2006
    5
    Arkansas
    Can anybody tell me if I am going to need to extend my driveshafts if I go with an 8" Skyjacker or Superlift kit.
  2. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Superlift 8" - NO
    Skyjacker 8" - I don't know
    I presently have a Superlift 8" on my '83 K10 and both front and rear shafts are bolted up and work great.
    Manny
    Edited: Well, I don't want to steer anyone wrong, so maybe there is a difference between the K10 and the K5. I'd listen to everyone. Sorry 'bout that...
  3. jwallace1029
    Dec 7, 2006
    5
    Arkansas
    Do you drive it often or just on the trails
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I don't know what kind of setup that guy has but there is no way you could get away with the stock shafts on your blazer. You will need an extended rear shaft that has a CV style at the top for angle and your front shaft will also need to be lengthened.
  5. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I had to get a new rear shaft with a 6" lift. Put a dana 60 up front and the extra lenghth at the yoke made the front shaft usable.
  6. pin_it_to_win_it
    pin_it_to_win_it Registered Member
    Jun 21, 2006
    94
    centeral coast california
    i have a 6" skyjacker on my 1985 K5 and it needed no work on the drive shafts. But i do not know for sure about the 8" skyjacker or superlift.
  7. tweek
    tweek 1/2 ton status
    Aug 13, 2003
    353
    montgomery, ny
    i run an 8" skyjacker lift, all springs on an '87 and needed both shafts to be lengthened..........
  8. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Short answer...yes.
    Had a buddy with a basically stock '82 K10 had to have a new shaft in the rear, don;t remember in the front.
    Give us a little more info though. What axles, t-case, etc. Or is it all stock?
