8" lift question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MaxCrack, May 11, 2001.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    8\" lift question
    I want to put about 8" of lift on a '75 K5. I have the ORD heavy duty front shackles and the 4" rear shackle flip kit.
    I will be extending the front shocks with the ford towers.
    I will be doing a cross over steering as soon as I get my D60 in a couple months or so and I have most of the parts for that except for the ones that need to be measured after the axle is in place.
    I will also be angling the rear shocks a little to get more range of motion for the D70 which may or may not stay(depending on brake issues).
    I have the longer brakelines and can get custom ones for cheap from a friend if I need extra long ones.
    I also want to move the front axle forward about an inch and a half.
    And I just bought a digital camera for lots of pictures.
    What I want to know is, what springs do you guys think I should get for the front and for the rear?
    Will an 8" set for the front and a 4" set for the rear be the right combination for a level truck?
    Is there anything else I will be needing?
    (also posted on the ORD forum)
    That's because I'm the devil.
