8" Lift with 6" Springs
Discussion in 'The Garage' started by Confedneck, Oct 24, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    8\" Lift with 6\" Springs
    ok so eventually i want to lift my truck 8" to run 37s or 38s...and i dont want 8" springs because they wont flex as well as shorter springs, and probably wont ride all that great...i figure with 6" front springs i have a couple options, give me your opinions..
    6" front springs, 2" front blocks (i know, i know, illegal AND stupid)
    6" front springs, drop the front spring mounts (how far would i have to drop them?)
    any other ideas on this??
  2. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Re: 8\" Lift with 6\" Springs
    Drop the front spring hangers/mounts. If you want to get two inches of lift, you'll have to drop them about 4". Probably get a piece of 4" square tubing, cut off the front mounts, weld the piece of tubing across to each of the frame horns (will also help re-inforce the frame up front), then attach the mounts to the bottom side of the tubing. I know two people who have done this before, and it turned out really well.
  3. Confedneck
    Nov 1, 2002
    5,236
    thats what i was thinking...and also thinking about capping the ends and welding up a 2" receiver to that mount, along with some of the big shackles for recovery?
  4. mountainexplorer
    Nov 14, 2001
    4,903
    Yeah, it would be a good point for a front hitch, maybe add a couple re-inforcements where you can.
    Also, forgot to add, doing this will also lessen an extreme pinion angle.
  5. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
  6. Confedneck
    Nov 1, 2002
    5,236
    thanks guys...i think i have it figured out now...so maybe in april or may ill get around to doing this and ill post up again with an update lol /forums/images/graemlins/thumb.gif
  7. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I run 6in springs and a 2in traction lifts. I get 2 inches of lift that I wanted, kept the softer spring rate plus helping axle wrap. Yeah I know how 80s but if it works it works. Ya cant argue w/ that.
    I fabbed my T/Ls to bolt into the pack so you arent just "sticking a block in there". Bolts in like the Zero rates do, plus helping stop axle wrap. It hurts me in flex a bit but not enough to bother me. Noone makes them anymore, but I can make a set up for you.
    I could definately feel the difference w/ them on the street, off roads kinda hard to judge since you never get used to any one area.
  8. Confedneck
    Nov 1, 2002
    5,236
    can you send me a picture of what you're talking about? or post one up?? /forums/images/graemlins/thumb.gif
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Look in my Webshots in the RE-Construction album. Theres a few pics of them in here .
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    why not lower both the front and rear ends of the front spring. Then you only need to lower the mounts 2" to get the lift you want. If you did that you could correct that front shackle angle at the same time.
  11. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    [/ QUOTE ]Actually dropping the front 2 inches and using a 2 inch longer shackle would also work. Saves having to work out the shackle pivot being in the frame. A 2 inch longer shackle is fairly common.
  12. Confedneck
    Nov 1, 2002
    5,236
    PI...those look like really long 2" blocks LOL...basically a traction bar (slapper bar)??
    cybrfire-so 2" box tubing up front and 2" longer shackles? so they would negate each other as far as correcting the pinion angle goes? maybe 3" front and 1" longer rear mounts?
  13. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    www.chuckstrucks.net sells a front crossmember with receiver built in. Its probably like 2 1/2" tall, under rockwell parts. Hill shackles are 2" longer than stock. 2" shackles + 2" front mount drops = 2" lift. I wouldn't drop the front mount farther than that. then you have 4" tall things sticking out there to smack stuff with.
  14. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    [/ QUOTE ]Thats pretty much the basic concept. Hey they work and I have flogged the snot out of mine.
    Next step for me is a 4 link and coils. /forums/images/graemlins/thinking.gif
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I always wonder about binding on good articulation with TB lift. If I ever go with 6" springs I will drop the front spring mounts, longer shackles, and ford 57" 2" lift springs out back. i don't like the factory front spring mounts, they seem so weak for what they do.
  16. Confedneck
    Nov 1, 2002
    5,236
    PI...thing is im only worried about the ride quality up front, because i plan on a shackle adaptation kit, or home made flip and 57s or custom springs in the rear..
  17. Confedneck
    Nov 1, 2002
    5,236
    sled..i cant find 2" lift 57s anywhere..got a source?
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    2 1/2" lift springs I guess they are. I don't have a source. I just put the 4" bds springs on and am doing a homebrewed flip with stock springs so not looking into this stuff yet.
  19. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I've never used longer shackles in the front so I can't speak from experiece. I moved my whole axle forward 4 plus inches and moved the rear hanger 5" to correct the angle. I did use ORD's front shackle kit which is a little longer shackle but don't know what effect it had on shackle angle as I didn't do it all by itself. Can somebody post up some pics of the longer shackle.
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Steve had the Hills on the UAV back in the day. There is a review in the product review section. I have ORD shackles too.
