8 lug 10 Bolt Swap information
Discussion in 'The Garage' started by redneckdude, Jan 22, 2005.
  1. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    Ive been registered on here for a while, and been lookin around here a lot. I know theres a tech article on here about it, but i need to know what all i HAVE to change. I have a 91 K5 with stock axles front and rear. What hubs do i need to look for? Do i HAVE to change my spindles? Wheres a good place to get these parts new? Some of this stuff id like to get new if its not too expensive. Thanks.
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    you need 3/4 ton backing plates, hubs, rotors, the spindles and bearings are the same. the calipers and pads are the same also.
    someone correct me if im wrong
  3. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    also i got my hubs and rotors from napa for like 100$ each, backing plates try LMC truck
  4. redneckdude
    Feb 21, 2004
    578
    Augusta, GA
    Thanks man. Did you get the hubs and rotors together for 100 per side? If so, i can deff manage that. If the calipers are the same, ill really be in business and happy that i won't have to possibly change my brake lines again. Ill check LMC for the backing plates. Thanks for the help.
  5. digity
    digity 1/2 ton status
    Oct 10, 2004
    184
    13
    Brentwood Ca
    Your stock calipers will be fine. New backing plates will be hard to find. Where bouts are you? I know of a shop in Ca. that has a few left.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The only thing you need to change is:
    Bearing hubs
    Rotors
    Brake backing plates
    The spindles are the same, the calipers are the same, the locking hubs are the same, the wheel bearings are the same.
    You just must make sure to get bearing hub assemblies that are for newer internal locking hub design. The older external stuff is different and uses different locking hubs and different spindles.
    When you do the swap this is the PERFECT time to change axleshaft ujoints, grease the spindle bearings, grease the wheel bearings, and if necessary (if there is play in them) change the ball joints.
    Harley
  7. redneckdude
    Feb 21, 2004
    578
    Augusta, GA
    Im in augusta, ga. If you could get a price for those plates id GREATLY appreciate it. i can't really buy much of anything else till the end of the month, but after that, im really gonna try to get these parts together...then on to the 14 bolt FF rear.
    Also, part of the reason i want to do this is because i need to get new rotors and don't feel like payin for new ones for a 6 lug...and its a great time to get new, thicker lug studs. Im glad to hear i only need those three things per side.
  8. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    yea it was 100 for one hub/rotor assembly, came with the studs pressed in, and new races
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Keep you eye on the for sale forum, they are in there for $50 alot of times. You dont REALLY need new hubs and backing plates so I would just go to a junkyard and rob the stuuf off a old truck. Alot cheaper than buying it new.
  10. redneckdude
    Feb 21, 2004
    578
    Augusta, GA
    Ill keep an eye out in the for sale forum. I need to get off my ass and check out the junk yards around here. I know theres some, just a lil bit of a drive. I don't have to get this stuff soon, since theres so much other stuff i need/want, but i will get it all eventually.
  11. clstolten
    clstolten 1/2 ton status
    Sep 4, 2002
    356
    Why don't you buy a complete used axle and use it, or take the parts you need. Should be able to get a complete 8 lug 10 bolt axle for about $100.
  12. redneckdude
    Feb 21, 2004
    578
    Augusta, GA
    depending on how cheap backing plates my be, i don't know if its worth saving that little extra money. I can't use the rotors and then id be left with an extra axle that would do me little good...plus its too much of a hassle to get an axle to my house...don't want to put it in the blazer...and i can't get hold of a pickup or trailor very easy...i think ill just pay that little extra...
