8 Lug 14 bolt SF disk break conversion????
Discussion in 'The Garage' started by y5mgisi, Aug 18, 2004.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Is it possible? How would i mount the rotors? does someone make a caliper braket that would work for this? Would i just use som like 75 3/4ton front rotors and the same calipers? COULD i just get longer studs and slide the rotor on over the studs(meaning i wouldent have to pull the shafts to remove the rotors). Also the truck has rear antilock so how would i contend with that.Clue me in /forums/images/graemlins/ears.gif
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think it was Blue85 that I sold a spare 14SF to and he did a disc brake conversion on it. Sedn him a PM...
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  4. dyeager535
    26,982
    191
    I think I'd be looking at taking the setup off of a 2000+ 8 lug SF if I had an 8 lug 14SF.
    I'd check first to see that the axle "flange" for the brakes didn't change of course, but if it hasn't, that would be the slickest setup.
