8-lug 15 inch wheels??
Discussion in 'The Garage' started by jms, Nov 26, 2002.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Stupid question, please bear with me: Can you run 8-lug 15 inch wheels (15x8, backspacing probably 3 1/2 or 3 3/8 inch) on a 10-bolt that's converted to 8-lug and on a 14 sf (drums)?? thanks, michael
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Yes. You will have to grind the calipers on the front though. Do a search, this has been discussed many times.
    Mike
  3. jms
    Jan 24, 2001
    1,683
    Ouch - caught by the SEARCH Police. Can the PROFILE Police be far behind?
    Thanks anyway, michael
  4. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I was under the impression that grinding on anything besides a 60 was either unnecessary, or at the very most a case-by-case basis. /forums/images/graemlins/confused.gif I have seen several sets of 15 inch 8 lug wheels on either a 10b or D44 front that did not require grinding, and in a variety of offsets.
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I had a 3/4 ton 10 bolt axle that I put 15x10 8-luggers on. I had to do quite a bit of grinding to it. My backspacing is around 4".
    It really wasn't that much different doing the grinding on the 60.
    -- Mike
  6. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Evidently the wheels I have seen used have a significantly smaller backspace than 4". /forums/images/graemlins/crazy.gif Learn something new on CK5 everyday! /forums/images/graemlins/thumb.gif
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The smaller backspacing makes for less work when installing on 8-lug axles, but pushes the entire wheel out of the wheelwell more. If also increases the stress on the axle itself since it takes the weight of the tire farther from the center of the axis of rotation. No big deal on d60's, but maybe more of a concern with a d44/10bolt.
    -- Mike
  8. jms
    Jan 24, 2001
    1,683
    Any idea which wheel brand/backspacing would fit without grinding? I'm thinking (cheap) steel, not alloys. As for spacing the wheel a bit further out, that might actually improve the scrub radius in my case. I'd be using skinny tires, so the load/stress issue may not be of concern.
  9. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    ???????????????????? I thought I answered your question???? Why the attitude? /forums/images/graemlins/confused.gif
    4WPW carries cheap steel wheels the the 15" 8 lug version that have 2 3/4 inch backspacing that will require little to no grinding.
    Mike
  10. jms
    Jan 24, 2001
    1,683
    Thanks for answering my question.
    BTW, have you noticed that lately everyone who doesn't ask about Rockwells, 44s, or 502 BBC crate motors gets slapped with the "Do a search..." thing?
    Thanks also for taking the time to answer my second question about the wheels, I do appreciate the information.
  11. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    /forums/images/graemlins/thumb.gif Yep, I have noticed that. I just thought you might get some more detailed info if you dug. I wasn't trying to be smart.
    No problem! /forums/images/graemlins/thumb.gif
    Mike
  12. jms
    Jan 24, 2001
    1,683
    I did dig. The info is scattered - that's why I decided to post. And, it seems those wheels you mentioned didn't come up before. They might be the way to go for me, thanks for pointing them out to me.
    michael
  13. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Mainly because damn near everything else relating to K5's has been covered ad nauseum. Including the merits of search, and why people don't respond to most posts. /forums/images/graemlins/wink.gif
  14. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Like Mike said, you can run wheels from 4WPW with a small backspacing. I'm running 2.5" backspacing, 15x10 8-lug Rockcrawlers from them and I only had to grind a little on one side where the casting line on the caliper was (this is on a D60). They are $60 each and the PN is 82-5181R2.5 for a white spoke wagon-style wheel. Hope this helps.
    Will
