8 lug axle conversion
Discussion in 'The Garage' started by chvymudin3388, Feb 12, 2006.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    im looking for the easiest cheapest way to go to 8 lugs i was wondering if 12 bolts came in 8 lug? i want stronger axles and of course theres nothing like the look of 8 bolts holding on youre wheels :D
  2. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Cheaper to put a 14BFF in back.
    Up front, switch outers from an 8-lug D44 or 10-bolt, they're identical parts.
    -- A
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    12 bolt didn't come 8 lug, its only marginally stronger than a 10 bolt anyway.
  4. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    sorry but by outers what all are you talking bout from the spindle out or what?
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah youd need caliper backing plate, hubs, and rotors
  6. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    ok thanks every one sounds like a plan in the making :D
  7. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    slightly incorrect in the case of my 88. before my 60 up front i went to 8 lug outers, etc. i didnt need to change calipers. my calipers worked i just had to grind a small little tab on the caliper so it would clear the 3/4 ton backing plate. shouldnt need new calipers.
  8. dremu
    Feb 27, 2000
    15,970
    462
    Yeah, the whether-you-need-calipers depends on brake lines more than 6- or 8- lug. In my case I was going from a '74 D44 to a 10-bolt, so I had to switch lines or calipers. If you're going from a later D44, I think, you're okay.
    -- A
  9. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    actually im thinking of going out getting the 14 bolt and finding a d 60 front cause i want strength to not a stock 1/2 ton front with 8 lug outers so yea
