8 lug conv??
Discussion in 'The Garage' started by unicknn, Sep 7, 2002.
  1. unicknn
    unicknn 1/2 ton status
    Jul 5, 2002
    138
    In San Diego now but Im from Texas
    How har is it to do this? Is it very expensive? What are the pros and cons of diong it?
    lmk
    Nick
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I assume you are talking about the front axle...It is easy...It took me about 4 hours from start to finish including grinding my 3/4 ton calipers for my 15" wheels... I had the 3/4 backing plat sitting around and I pick up the hub/rotor assemblies from AutoZone for $100 a piece and the bearings were like $30 So $230 or so... I did it so I had wheel that matched front and rear b/c I put a 14bolt axle in the rear which has an 8 on 6.5" lug pattern and I wanted the same for the front...
    Chris
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Its easy.If you can turn a wrench,you can do it.
    I spent $250 for my parts.I got the hubs and rotors,spindles,wheel bearings,and backing plates.My parts were from a 10 bolt and I put them on my 44.
    The pro part of the swap is having 8 lugs up front to match the 14 bolt,ya only gotta carry one spare /forums/images/icons/grin.gif No real cons to it.
    I did a search and found alot of good info.
