8 lug conversion HELP
Discussion in 'The Garage' started by Dogman12, Jan 9, 2007.
  1. Dogman12
    Dogman12 1/2 ton status
    Nov 12, 2006
    111
    Easthamptom Ma. 01027
    I have been gathering all th eparts to do the 14 bolt swap change to disc brakes and convert the front to 8 lugs. I have both axles stripped down ready for paint and figured i would check and see how it all fit before paint. I was mocking up the front when i noticed the 8 lig hubs do not have splines in them for the drive flange of the locking hub to slide into. I know there is a large bearing and small bearing front, but this one is a ten bolt. Is there two styles of 3/4 ton locking hubs? Thanks
    Jesse
  2. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    Without seeing them I'd say you have a set of hubs for external lockout's or drive flanges.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    A pic of what you've got would be a bonus. I'm also suspecting what 1ton thinks.
  4. Dogman12
    Nov 12, 2006
    111
    I think you guys are right, i searched all over looks like from a 76, 3/4 ton dana 44 hd. Do you guys know if they will work with the 10 bolt shaft? I am assuming i will need to get rotors for a 76 and down 3/4 ton. The 77 ones i purchased look like they mount up different.
    Thanks for the fast reply.
    Jesse
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    the rotors are the same, the only difference is that you need external style lockouts, the newer style ('78+) wont work
  6. 1-tonmudder
    Apr 24, 2005
    3,052
    I have the correct hubs
  7. Dogman12
    Nov 12, 2006
    111
    Are they complete, how much do you want for them? do you take paypal.
    Again thanks for replies. I am new to building Chevy, so i appreciate the help.
    Jesse
  8. 1-tonmudder
    Apr 24, 2005
    3,052
    They are off of a 82ish 8 lug 10 bolt,I removed the rotors to use for the rear disc Im putting on so you will have to use your rotors.
    Pm'd ya.
