8 lug conversion idea
Discussion in 'The Garage' started by FRIZZLEFRY, Mar 21, 2002.
  1. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Has anyone turned 1/8"-3/16" off the diameter of their 8 lug rotors and used 1/2 ton backing plates?Im converting my 44 to 8 lug and before changing to the 3/4 ton backing plates last night I threw on the 8 lug rotors with the 1/2 ton backing plate still on.The rotor almost went on and I could almost bolt up the caliper.If I had more time I would turn down the diameter of the rotor a bit.It seems that if you did this you wouldnt have to grind to get 15" wheels to fit.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hmmmm, grind the rotor? Nope never did that/forums/images/icons/wink.gif!
    Can't wait to see your project!!!/forums/images/icons/cool.gif
  3. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Put the front on jack stands, pull the rear shaft, putit in 4H and let the front spin and hit it with a grinder as it spins. We've done it to rear rotors to make them fit on race cars, but probably not recommended on the street.
  4. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I wasnt gonna grind them,I was gonna stick them on the lathe and turn them down that way.
    If this worked you would not need to find the 3/4 ton backing plates.And if you get rotors and hubs with wheel bearings to match the spindle you have (early or late model spindle) you would not need to buy spindles.You would only need the rotor/hub.
    If turning the rotor down worked ,all you would need for the conversion would be the correct hub and rotor for your spindle and a lathe.
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Great idea! If it works out let us know! I am needing to convert a 10 blt. Would be cool to not have to grind a bunch.
