8-lug conversion question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Casey 86K5, May 12, 2000.
  1. Casey 86K5
    Casey 86K5 1/2 ton status
    119
    Brownsburg, Indiana
    I am finally getting to the point where I can put my 14 bolt FF in, but I am not sure what I have to do to convert the front 10 bolt to 8-lug. I have been told that I just need to swap in 8-lug hubs and rotors. Is this right? I have access to an '86 3/4 ton 4x4 that I can take the parts off of. One more question- does anyone know if NAPA sells the conversion u-joint used when going from a 1310 to a 1350? The guy at napa couldnt find one and said to bring him a part number.
    thanks in advance for any help
    Casey
  2. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Napa part no. 447
    350 Vortec TPI D60 14Bolt 4.56 4"lift 35 BFG A/T
  3. Casey 86K5
    119
    Brownsburg, Indiana
    thanks for the number, will be heading up to napa tomorrow!
  4. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    You need to take from the spindes out.I believe that is all you could take the shafts while your there just in case the outer stub is different or for spares.Brady
  5. Unless you have a Dana44 front then all you need to do you is swap the hub and rotors. BTW your old tranny lost 3rd and 4th gear a few days ago.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  6. Casey 86K5
    119
    Brownsburg, Indiana
    Thanks BigBurb, feel kind of bad for selling you a bum tranny.
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>It would probably be easier to change the whole 3/4 ton axle then it would be to take apart both. It would just swap right in. What frontend do you have now?</font color=blue>
  8. Casey 86K5
    119
    Brownsburg, Indiana
    That is what I wanted to do, but I pulled the cover on the 10-bolt in the donor truck and it doesn't look too good in there (lots of metal in oil), and I dont want to mess with rebuilding it.
  9. Damn thing had 80,000 miles on it !! I just wish it would have lasted longer, until I had the money for a good one with all the mods.
  10. Casey 86K5
    119
    Brownsburg, Indiana
    It should have lasted longer- but when I bought the truck, it did not have a trans cooler on it, so that may be why you lost 3-4 so soon. I think all 700's should have had an aux. cooler on them from the factory, the radiator does not help out cooling at all.
