8 lug conversion questions??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Gold Rush, Jan 18, 2002.
  1. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    O.K. guys and gals,
    I am doing my 8 lug conversion and came across what seems to be unusual. First of all I bought my parts from a guy on the Pirate board and he told me they were all 8 lug 10 bolt stuff. I have a D44 in my 75K5. I installed new ball joints and then proceeded to install my "new" 8 lug bearing hubs & rotors. By the way if you do this your outer race and bearing may just be the same as the 8lug hubs. At least mine was anyways. In order to get my 8X15 rims with 3.5" backspacing to fit I had to do some extreme grinding! Looks like some metal may have to be welded on the inside of my caliper bracket to give some strength back to it. I've heard of D60's being ground this bad to fit a 15" rim but never heard of anyone having to grind to convert a D44.
    Has anyone else had to do this??????????
    David
    <a target="_blank" href=http://www.extremeblazer.com>ExtremeBlazer</a>
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I know i had to grind a lot, not enough to lessen the strength but it was a lot. I had to grind the backing plate also.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, 14ff, (soon to be- dana 60, flatbed,and 39.5" TSL's)
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I ground so much off the backing plate that the tabs supporting the sides of the caliper fell off. They were so thin due to the amount of grinding that I just bent them off. So far no problems. I check for abnormal wear on the rotors and for loosened bolts. So far so good (5 months). If I were to do it again I'd try to heat the backing plate and pound the hell out of it until the rim fit.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I think Triaged just got some 15x10s with 3.5" of back space and he only had to do minimal grinding.I wonder what the dif is between different 8 lug set ups be it 10 bolt or D44?
    Some people shouldnt drive anything bigger than their head.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  5. Gold Rush
    1,498
    Not sure that there is any diff between the 10 and D44. I do have the tranny in, the rear shock mounts and the rear cross member done though. The Front conversion should be done this week sometime. I can't wait to get out and try all my new stuff!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Oh the winch will probably take a couple weeks to get installed. I need to take it apart and clean and lube everything up then fabricate a new bumper to mount it to.
    David
  6. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I had to do that much grinding to fit the 15's on my 8 lug Dana 44...it's been a year now and no problems though. I might still re-ienforce that area of the backing plate though.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
