8 lug conversion
Discussion in 'The Garage' started by smprider112, Sep 8, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    Ok so I know to convert my d44 to 8lug...I need the brake backing plates, the hubs and the rotors...is there anything else? and also can I get these outta Non-chevy trucks?? Like Ford or Dodge d44's? or are they different?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    with a d44 i think you need the spindles also.
    i would get every thing from a chevy, a 10b or d44 will both work and are both the same
  3. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    Ya I wish I could find chevy...at the U-pull it there arnt any 3/4 tons....but there is alot of fords so I was hoping they'd work, or dodge.
  4. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Nope... the spindles are the same. Spindles, bearings, lockouts, stub shafts are all the same. You just need baking plates (to prperly position the caliper on the bigger rotor) and the hub/rotor assembly (with the needed 8 lugs). Deminsionally, I think the hub is the same as well just needs to have 8 holes (not that I would consider drilling a 6 lug hub).
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Have you tried the U-pull-it out in sherwood yet? Last time I was there(last month)there were a crap load of 3/4tons in there /forums/images/graemlins/thumb.gif
  6. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    thats the one I always goto!! they have tons of 3/4 tons...but not 4x4 /forums/images/graemlins/frown.gif I think the last time I was there prolly 2 weeks ago, they had only 3 1/2ton 4x4's 2 blazers and a k10 longbox....they're front axles where pretty much intact...but who needs 1/2 ton /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    I need to hit the one in damascus(SP?) last time I was there they had TONZ of barely picked thru vehicles...of course I was there with my lil brother lookin for mustang stuff so I never got to cruise thru the chevys /forums/images/graemlins/whistling.gif
    But I have seen TONZ of ford 3/4 tons and am wondering will there parts work /forums/images/graemlins/dunno.gif
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    To the best of my knowledge....nope
  8. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yes they do. I was gonna do ford rotors, calipers and backing plates on mine but already had GMs coming out my ears. I can't remember what years the stuff is off of though but I know there is a weite up online of a bronco switching to GM 8 lugs... Not a very good reply but it gives ya options,LOL
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    No D44 and 10B spindles are't always the same!
    1st design D44's used a smaller inner wheel bearing and on 3/4-ton's used external locking hubs.
    2nd design D44's (which started around 77) use the same larger inner wheel bearings that 10 bolts use and use an internal locking hub like a regular D44/10B 1/2-ton axle.
  10. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    My mistake. I was speaking of the modern era axles. I wasn't aware of the differences in the old ones. /forums/images/graemlins/blush.gif
