8 Lug conversion
Discussion in 'The Garage' started by stockk5, Jun 16, 2005.
  1. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    hey, i have a 10bolt front right now, i wanna get bigger tires on my truck for now, i have a 14bolt rear, so in time ill save for the dana 60 but im keeping my 10bolt for now. Where can you get a 8lug conversion for my 10bolt?
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    NAPA, as far as I know all you need are the outers.
  3. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    Find a 3/4 ton 10bolt or D44 and take off everything from the knuckle out...
    Backing plate
    Spindle
    Hub/rotor assembly
    and lockouts
    You can reuse your 1/2 ton calipers
    All of this stuff just bolts right up to your axle...If you have any questions you can PM or email me lukerdl@auburn.edu (I've done this swap like 6 times :D )
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,014
    848
    Pinckney, MI
    Look at the tech section of the main page. Its really easy, If you have changed your rotors before its basically the same thing! just you put a new backing plate and 8 lug rotor/hub on
  5. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    thanks! good to hear its not to complex
  6. jekquistk5
    Jan 18, 2004
    11,014
    848
    Pinckney, MI
    No problem, but if you grab junkyard parts atleast spend a few bucks and get new wheel bearings :thumb:
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    You dont need new lockouts, your old ones will still fit.
    One thing to look for is if you find a 10b with the 8 lug you only need the backing plate, and hub/rotor assembly.
    But if you find a D44 there are 2 different sized outer bearings so make sure you see which one it is and if it is the smaller version you need the spindals also.
