8 lug conversion ?
Discussion in '1992-Present Chevy & GMC models' started by clarkjw24, Feb 28, 2006.
  1. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    How do I get 8 lugs on the front of my IFS truck? Is it a simple swap? Can I just buy new rotors and crap.
  2. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    lots of stuff i heard. but the easy short way is no. not easy swap. mounts are diffrent for front diff and lots of other stuff. but i just run 2x4 88-ups so i dont have first hand info. and i like my 60s better.:D
  3. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I was thinking of putting in a FF and just wanted the front to match. Also when the day came for a 60, my rims would work.:doah:
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Can't do it unless you go to a solid front axle or have incredible fab skills. :( On our '94 Sub I replaced the rear 10-bolt with a 6-lug, 14-bolt SF. It's WAY beefier than the 10-bolt and my old wheels bolted right up. :) Found it under an extended cab pickup at the JY.
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I've already got a 6 lug 14 semi under the rear but everyone likes a ff. I guess its no big deal, I was just wondering what there was to it. Thought maybe some HD stuff would bolt up.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    SFA baby!
  7. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    why not just some 6 to eight lug adapters?
  8. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Won't that make my front wider? Also those things are a little pricey.
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    wider yes
    pricey yes
    think i saw some for sale in the for sale forums
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    This is why your's has the SF14B. "Soulemate" on here gave the best description. Here is the post with the good info:
    http://coloradok5.com/forums/showthread.php?t=106727
  11. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Thanks Jim that answered my question. I guess for now I'll just swap out the 3.73 sf I've got in the shop.
    I fixed the brake lights and turn signals. Brake pedal switch was bad and the turn signals had the wrong bulbs in it causing electrical havic throughout. Also fixed the door jam switch and rear wiper. Just got to get an a/c compressor now, thats what's roaring. Also need to figure out why the gas hand works when it want's too.
    Your tag is coming UPS.
  12. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Glad the lights were an easy fix. I felt so bad when you called me. I never would have sent you off if I knew about. I would have had them fixed before you got here if I knew they were bad.
  13. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Or you could convert your ff to a 6 lug. Have the hubs re drilled to 6 lug, thats what we did to my buddies tahoe.
  14. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Pull the studs on the front. Plug weld the holes up and redrill for 8 lug.
