8 lug conversion
Discussion in 'The Garage' started by SF87K5, Jan 15, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    What is need to convert a 6 lug to a 8 lug on a 10 bolt. I have the 3/4 ton rotors do I also need the calipers and is there anything else I would need?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You can re-use your 1/2 ton calipers and hubs....but everything else from the axle tubes out needs to be replaced. (ie, backing plates, spindle, rotor, etc)
  3. SF87K5
    Oct 27, 2002
    1,105
    So I need the rotors, spindle, and back plate. Is that it or is there something else I am missing?
  4. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Not sure if you know this but there is a write up about it in the technical section up top. Its for a D44 but is the same for the 10 bolt.
  5. heavy4x4
    Aug 28, 2002
    3,270
  6. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    No need for a new spindle. You need the rotor, hub assembly (not the locking hub, the part the rotor is attatched to that holds the bearing races), and the backing plate. - Doug
