8 Lug D44 Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tommy, Apr 12, 2000.
  1. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    What all would be needed to change a Dana 44 w/discs (6lug) to * lugg? Is the size of the rotors the same, could the same calipers be used? Any help would be appreciated. I'm trying to help a friend on his Jeep. He wants to have 8 lug all the way around.
  2. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    I believe that the rotors on the 8 lug are bigger because the 8 lug is 3/4 ton & up. You should be able to get both left and right knuckle assemblies and switch them w/the 6 bolt... I'm pretty sure on this but someone correct me if I'm wrong.
    NEVER been stuck... *yet*
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Just get the rotors, hubs, and backing plates from a 3/4 ton GM 4x4. You can get the rotors new but I had a hard time finding rotors with hubs already pressed in, so I got the hubs off of the trashed set of rotors at a local junkyard. The calipers are the same on a 1/2 ton. E-mial me if I can help out any more.
    BIGJ
