8 lug front diff. from a burb?
Discussion in 'The Garage' started by bajaviking, May 17, 2005.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    A buddy of mine has a fronf diff. from an 81 suburban that he wants to sell to me. How much is a reasonable price and does an 81 burb have the 10 bolt or the Dana 44?
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Should be a 10 bolt
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Its going to be a 10 bolt, I would give no more than $200 for it. Maybe $250 if the brakes are in good shape.
  4. wildcatkit52
    wildcatkit52 Registered Member
    Apr 12, 2005
    65
    Arkansas
    Well the last year they put the 44 in was 1980 and they started using 10b in 1977 to 1991. Like they said, it is gonna be a 10b unless it has been changed. If it is pretty much round then it is a GM 10b. If it has 8 easily identified flat edges on the cover then it is not a GM 10b. If it looks like that then you should be able to look for the model number on the housing at the bottom right corner if looking at it from the front side with cover on it.
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Should be a 10B, but those years were goofy, GM was kind of using both axles. I pulled my 8 lugger 10B from a '79 Burb.
