8 lug Furd bolt patterns....
Discussion in 'The Garage' started by SUBFAN, Sep 29, 2005.
  1. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    When did they switch from the 8x6.5" to the 8x170mm?
    What year, or what axle????
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    99-up super turds:D
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    yeah, the ford stupid duty with the powerjoke diesel! :haha: :haha: :haha:
  4. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Thanks....Cheap tires for the new crapola trailer :woot: :woot: :woot: :woot:
    Maybe the 14FF will have 4.56's and a Detroit....(wakes up from the dream.)
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Oh the power is no joke, but being on a third turbo in less than 20,000 miles is :crazy:
    Yeah, they went to metric in '99, that's why I can't put my 39.5's on our 2004.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you must be talking 6.0L. Friend of mine has gone through a turbo, injectors, injector cups, and a few other things. Really any other company would have replaced his motor by now... not Ford.
  7. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    I am glad I don't own something that gets recals even after it is 10 years old.
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    [RANT/HIJACK]Yep, the first turbo that went blew 1,000 miles after I put a pyrometer in. I figured that somehow I'd overlooked a minute shaving (I pulled the manifold when I did it) and it ruined a bearing. Talked to the tech and it was so loaded with soot it would barely spin which was consistant with the low boost numbers I'd been seeing even under heavy load. Injectors, cam position sensor, reverse gear cluster (not really the PS's fault), egr valve, more injectors, a couple of new flashes and a new wiring harness later...the turbo went again but this time nobody is saying anything which I'm not even sure is legal. I pretty much called dibs on the truck when it came time to be sold but I wouldn't even consider a 6.0 anymore. Everybody raves that for every bad one you hear about there are a million good ones....we must just be that lucky.[/RANT]
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    everyone I hear about has a bad one story so I'd say for every bad one there is 1/2 a good one.
  10. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    any clue why they did this?
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    To the metric bolt pattern? In '99 they went to hub-centric assemblies on SD's. I think they switched the bolt pattern up to try and prevent people from running non hub-centric wheels on hub-centric assemblies.
  12. sweetk30
    Nov 1, 2004
    25,538
    538
    good point . but almost all rims have been hub centric for years. i do tires all day so i get to see lots of vehicles. now if this were true then why do all aftermarket rims come non hub centric? but thay do offer adaptor rings to do this if needed. i have found that the lugnuts will center it plenty good.
    as for ford doing this to make it so only non hub centric bolt on. i say this is why thay did it ( ford ) as the logo is thay circled the problem allready.:D
  13. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    yup, i found out the hard way ordering rims.i drove from detroit to 4wheelparts almost PENN.to avoid shipping and return charges.+ i have a v-10 no deisel here. :laugh: if chevy had a solid front axle i would have got one. :doah: STERLING drivetranes :rolleyes: but as far as a work truck that 350 carries 3800 to 4500 lbs all day barly squating it. :D
