8 Lug Rim Question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chaka454, Mar 7, 2002.
  1. chaka454
    chaka454 1/2 ton status
    Nov 13, 2001
    199
    California
    Hey guys I'm kinda confused, I'm about to buy some 8 lug rims, I'm finally going 1ton on my 73K5 but I see 8 lug rims for #odge, for #ord, and for CHEVY is there a difference between all this or what should I look for when I get the rims for my 14 bolt rearend thanks and sorry if this is a stupid question.
  2. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    The lug spacing is different
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    AFAIK all the 8 lug paterns are the same except for the new fords (which went to a metric patern)
    I think it is 8 on 6.5"
  4. chaka454
    Nov 13, 2001
    199
    California
    Damn I was affraid of that, so I cant put rims on my Chevy from a #ord, or a #odge ?
  5. Stomp
    Feb 23, 2002
    168
    Then again, I could be wrong
  6. chaka454
    Nov 13, 2001
    199
    California
    cool, I'll keep looking for the rims
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I thought it was only newer rims off fords that wouldn't fit on older Chevy's. IE 99+. I may be way off base, but I thought any 8 lug rims from F*rd or D*dge would fit a Chevy. Except the 8 lug rims from Superduty Furds. Like I said I might be wa off base here.
  8. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    dodge chevy and ford 8 lug rims are the same lug pattern (8 on 6.5) Where you may run into a problem is the center hole. Ford didnt change the bolt pattern until 99 & thats only on the super duties (8 on 170 mm). The newer chevy steel wheels may have to small of a center hole to fit over the hub of the 14 bolt. The new dodge wheels & the older body style ford wheels will still fit the 14 bolts.
    Just make sure you test fit them before you buy them.
    Also keep in mind if your running a dana 60 up frt to make sure the wheel will seat all the way. The 60's hub is larger than the 14 bolt hub. So you could find a wheel that fit on the rear but then might not fit the frt.
    Hope this helps
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i just put a dodge dana 60 in my blazer and the center hole is a different size from my chevy rims all i had to do was grind a little out to make them fit /forums/images/icons/smile.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    are you after stock OEM type wheels or aftermarket
    the word on OEM is the ford ones made by Accuride are the good ones.
    I have them on my dodge axles under my chev truck
  11. chaka454
    Nov 13, 2001
    199
    California
    Well I was looking for something like the Eagle 589's 8 lug, one more thing anybody got some rims?
  12. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    i got some 16x8 8 lug (5) aluminum for $225 negotiable im in Long Beach
