8 lug size
Discussion in 'The Garage' started by Janitorjim8, Dec 13, 2005.
  1. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    does anyone know if ford 8 lug and chevy 8 lug are the same size and what size they are? The truck is a chevy 97 3/4 ton.
  2. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    8 on 6.5 for all Ford Dodge and Chevy prior to the 99-current Ford superduty and Excursion. Those are 8 on 200 something MM.
    So in short they all work other than the 99-current ford superduties.
  3. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    yabbot..
    I had ford 8 lug rims on my 74 GMC..only thing you need to watch for is the lug nuts on fords have larger and different tapers than GM ones,so I used the ford lug nuts with the 1-1/16" hex.(same 9/16" thread though).I'm not sure, but Chevy ones could possibly pull thru the rims!..:eek1:
    Dodge 8 lug rims are the same bolt pattern,(older than 87 at least)--but some have smaller center holes,and won't fit over the axle flange..fords have the biggest center hole,and fit everything --some guys say its not good to run rims with the center hole bigger than the axle flange,but I carried tons of weight in my truck with no troubles..most "aftermarket" wheels all come with the bigger Ford sized center hole too..:crazy:
