8 lug swap
Discussion in 'The Garage' started by bowtiewrench, Mar 14, 2006.
  1. bowtiewrench
    bowtiewrench Registered Member
    Oct 19, 2004
    24
    Woburn, Mass
    Is there any place online I can buy everything I need to convert my 1990 k5's front diff over to an 8 lug. Im talking knuckes, hubs, discs everything. Also has anyone put a newer 2001 and up 14 bolt out of a 2500hd or equavalent in a k5 yet? Thanks
    Alex
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i dont think that the swap is worth it...if it is an AAM1150, which, as far as i know, arent any traction devices available for it yet.
    i dunno about the AAM1050 which it could be that.
    plus i think they have dual piston rear brakes which would require either a new master or prop valve, or both.
    with as many 14 bolts that are out there, unless it was free, id pass.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You do not need to change your knuckles, spindles, locking hubs if you swap in 8 lug stuff from an internal hub axle. The only thing that must be changed is the hub and rotor assembly (bearing hub and brake rotor). You can get that stuff at your local parts house.
    Harley
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    caliper brackets too ;)
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I knew I was forgetting something. :doah: I havn't seen or replied to one of these post in a long time. I am getting rusty.:crazy:
    Harley
