8 lug tahoe
Discussion in '1992-Present Chevy & GMC models' started by K5Chris, Dec 30, 2006.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    just thought i'd post these pics of this 8 lug tahoe i saw. i didnt see what he did to convert it, but its got a broken cv shaft.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    a broken CV? never.... does look cool
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    291
    Truckee, CA
    I always wished they built those. A tahoe is a good size, and has an ok wheelbase to be able to tow a decent amount. Prolly not as much as a burb, but a 4l80e in a tahoe would rock.
    I wonder if he put that body on a 3/4" frame, or if he just swapped suspensions......
  4. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    It's a stock frame and suspension it looks like. I'm guessing he just used some 6-to-8 lug spacers up front and a 3/4 ton rear axle. I wish they came 3/4 ton from the factory too, that would be sweet.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    now that you mention it the front is pretty wide for such narrow tires. Probably what he did.
    eh what is the wheelbase of one of those things? I think my long bed single cab is like 125. Its not enough for me. I need to get a crew cab if I am really going ot be towing crap anymore.
  6. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    the track width on those is wider to begin with, and the suspension lift might have added to the width. i believe there is some way of swapping the 3/4 ton suspension including the 9.25" diff. i dont know the details though.
  7. dhcomp
    Mar 17, 2001
    9,862
    291
    Truckee, CA
    I thought they didnt' make 6 to 8 lug adapters?
  8. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Im sure its possible if you really want to do do it but everything is different from 1/2 to 3/4, frame mount locations and sizes of everything so it would be an incredible amount of work to pull it off..
  9. chevytaHOE5674
    chevytaHOE5674 Registered Member
    Jan 4, 2006
    28
    Houghton Mi
    i like it i wish i knew how he did it so i could run my 14 bolt FF rear axle with some type of 8 lug front until i do my SAS.
  10. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    gasp, could it be a 3/4 ton sub?
  11. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    6 to 8 lug adpters can be found, and this would also explain the wider track
  12. thezentree
    Sep 19, 2003
    7,198
    NC
    IIRC it's something like 111"
    Edit: In light of Jeremy's post, I was talking about 4dr Yukon/Tahoes
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    your wheelbase is 131.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    gasp, no, its too short.
    the wheelwell cutout in the door is a dead giveaway that is a Hoe.
    here's a Burb.
