8 lug to 6 lug adapters
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Dec 24, 2002.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Anyone know of a company that makes a set. I want to stay 6 lug, but put a 14 ff in it.
    Dan /forums/images/graemlins/burb.gif
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    You can convert the the FF to 6 Lug, PM TonyP he's doing on for his K5 right now.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was going to suggest the same thing, but I think he wants to go to the D60 front later so he would have to convert that to 6 lug or convert the 14bff back to 8 lug.
  4. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    wheels!! $$ 8 lug 15 " wheels
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Harley is right, it will get a dana 60 up front sooner or later. Thats why I want to do adapters. but if they arent out there, then I guess I will start looking for 3/4 outers for now, so try and find another 60.
  6. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    chassis tech supposedly makes 8 lug to 6 lug adapters, but there is no pic, so I'll believe it when I see it. I think the site is www.justadapters.com
  7. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    They are like 80 bucks apiece why would you want to spend that when you can get 2 rims for like a 100.. Just a thought.
  8. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I'd like to know more about this adapter 8 to 6 lug. If you upgrade the rear to a FF, you won't want to have 2 rims in back that are 8 and 2 rims in fromt that are 6. I couldn't get anything on the justadapers link.
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I believe TonyP's setup would allow you to return the 14 bolt back to 8-lug just by pressing the lub bolts back out should you get a Dana 60 up front. It would also help match front and rear axle widths. There's no doubt about it, having to bring along 2 spares when your front and rear axles have different bolt patterns would not be fun.
  10. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I've got a set that will convert the 8 lug to 6 lug bolt pattern, it allows you to keep your 8 lug pattern for when you find that golden Dana 60.
    I can't find the $1000.00 for the Dana or the new rims and tires, and I don't want to have 2 tires hanging on my truck somewhere. I could make them out of alum 1" wide or steel 1/2" wide...
  11. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    What kind of money are we talking about for you to make me a pair of them? I'm not sure what would be better, aluminum or steel. Any advantages either way?
  12. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    Yea how much are we talkin /forums/images/graemlins/deal.gif, cuz thats exactly what i need! I bought a 14b FF and really wanna keep the rims i have now.
  13. TONYP
    Aug 13, 2002
    2,116
    so cal
    the alum will move your tire out 1" where the steel is only 1/2" of movement. both will do the same job..
  14. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I think there is a lot of interest in these adapters. We just need some cost numbers! /forums/images/graemlins/smile.gif
    And the thing is, not that a set of 8 lug wheels are expensive, its that I have 2 sets of 15" wheels and tires. One set is a cheap steel set of whites but they have 35" TSL Sxs on them, the other is a set of steel wheels that I looked for 3 months to find, not real high dollor, with 35" radial muds on them. The hassle of selling 2 sets of 15" tires, selling 2 sets of 15" wheels, buying new tires (2 sets), and buying wheels that are ugly! Hehe. Its worth the extra for adapters I think. Sp TonyP, give us an idea of prices please!
    Mike
  15. TONYP
    Aug 13, 2002
    2,116
    so cal
    You would have to find a machine shop to turn down the hub and axles.
    Turn down axle and hub to 4-5/16”inch, then the ring and 6 lug rim will fit.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd be interested just cause 6 lug wheels are a dime a dozen...plus I could keep my 3/4 tons and possibly get aluminum wheels if they'd clear my brakes.
    The cool thing is if you had them in the back and had a 6 lug front, the wheel tracks would match.
  17. TONYP
    Aug 13, 2002
    2,116
    so cal
    Thing you need to have done to make this work.
    1- Outside hub dia.(where rims goes over the hub) will have to be turned down to 4-5/16” inch
    2- Axle outside plate will be turned down to 4-5/16”inch
    This would have to be done by a machine shop with a lathe and you would tell them the tolerance is +/- 1/16”inch.
    This would be the limiting factor for smoeguys, but if you can get this done then the adapter ring would be the wat to go... /forums/images/graemlins/k5.gif
  18. TONYP
    Aug 13, 2002
    2,116
    so cal
    this is what I've made up.....
  19. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats one hell-of-a peice of work Tony. I'm dying to see how the steel one comes out!
  20. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Don't forget that the 4-5/16" is for aftermarket wheels. Factory wheels have a smaller center hole. Aftermarket wheels have a larger center hole to fit yota's as well.
