8 lug to 6 lug
Discussion in 'The Garage' started by mrmojo32, Sep 15, 2006.
  1. mrmojo32
    mrmojo32 Registered Member
    Aug 26, 2005
    31
    LOUISIANA
    If I go to a 14 bolt rear end with 8 lug wheel pattern how can I keep my current wheels?
    I have the stock 15"x10" ralley wheels and I would like to keep them. Is there an adapter that will let me go from 8lug pattern to 6lug? If there is such a thing where can I get one?
    Also does anyone know if thye make this rim in 8 lug?
    Thanks.
  2. dremu
    Feb 27, 2000
    15,951
    440
    East of San Francisco
    Holy big pix, Batman! :)
    Those rims are 15x8, btw, not 10" wide. 8" was as wide as they came -- face it, for 31x10.50's (biggest factory size), an 8" rim is as wide as need be! :)
    You CAN get adapters, but they get pricey fast. 8-lug rims can be had for less; not in the factory style, but check out Summit Racing for decent/cheap steelies.
    -- A
  3. mrmojo32
    Aug 26, 2005
    31
    LOUISIANA
    Size
    Thats good information to know about it's width. They must also make a 6" or something because I always see this same style rim that I know is not as wide as these.
    As for just getting 8 lug wheels rather than using an adaptor.....
    Then I would have to carry 2 spares and would never be able to rotate tires.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    You may be better off finding a 14SF 6 lugger... Stronger than a 10b and 12b, but not as stronger as a 14ff.
    There is one other option. Grady's off-road used to make a billet hub for the 14f with a 6 lug pattern. You may be able to try and find a set of those. Or take the hubs to a local machine shop and see if they can machine the OD down on the wheelbearing area and then fill and re-drill the pattern....
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Purdy truck, purdy!!! :D
  6. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
  7. mrmojo32
    Aug 26, 2005
    31
    LOUISIANA
  8. dremu
    Feb 27, 2000
    15,951
    440
    Huh?
    I meant all FIVE rims =)) ... you can switch the front to 8-lug just by changing the outers (hubs and rotors), and then drop in a 14BFF in back.
    -- A
  9. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    id just convert the front to 8 lug as well using the 8 lug outers.
  10. mrmojo32
    Aug 26, 2005
    31
    LOUISIANA
    Ok
    Duh! Ok.... I follow you now. :D
  11. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Stockton makes those in an 8 lug but they aren't cheap like 150 last time I looked,
  12. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I just did the front swap to 8 lugs and it was not hard at all. you just need the rotors and hubs, backing plates and a mathcing set of locking hubs. it was pretty easy(easier than I made it) It cost 200.00 plus wheels @39$ each for cheep wagon wheels( figured I am just going to tear them up) just remeber you are going to have to grind the pee pee out of the front to get clearance enough to put the wheels on.
    Replacing the rear with a 14b and detroit is incredible off road. you will be totally astounded at what you will start aiming the truck at to climb. deffinently one of the best upgrades.
  13. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Even with wheel adapters, you'd need to machine down the 14bFF hub snout, and open the center hole on the stock wheels.
  14. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    No 8 to 6 lug adapters are available, your only option is a new hub or change the front. It is much cheaper to change the front to 8.
    I charge around $450 for the steel 6 lug hubs and $650 for the aluminum.
    That price doesn't include brakes so yeah it's rather pricey...
