8 luggers question
Discussion in 'The Garage' started by laketex, Jul 27, 2003.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Is the ford superduty lug pattern the same as ours? /forums/images/graemlins/thinking.gif
  2. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    no....they are metric.
    Doc
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Got this info off of pirate....
    2000 F350/F450/F550 DRW (balljoint, metric 8x170mm wheel bolt pattern F350 / 8x220mm F450/F550, unit bearing hub)
    2000.5 F350/F450/F550 DRW (balljoint, metric 8x170mm wheel bolt pattern F350 / 8x220mm F450/F550, unit bearing hub)
    2001 F350 DRW (balljoint, metric 8x170mm wheel bolt pattern, unit bearing hub)
    2001-02 F450/F550 DRW (balljoint, metric 8x220mm wheel bolt pattern, unit bearing hub)
    2002 F250/F350 SRW (balljoint, metric 8x170mm wheel bolt pattern, unit bearing hub)
    2002 F450/F550 DRW (balljoint, metric 8x220mm wheel bolt pattern, unit bearing hub
  4. laketex
    6,220
    North Texas
    thanks fellas...glad i didnt buy them then.
