8 lugs adaptor \ spacer
Discussion in 'The Garage' started by arik2, Sep 9, 2004.
  1. arik2
    arik2 Registered Member
    May 25, 2003
    9
    8 lugs adaptor \\ spacer
    Hi,
    I'm looking for an adaptor \ spacer kit that will give me the possibility to add about an 1" space for my rims.
    I'm going to install on my CUCV some hummer rims but when they installed on the front axle - they touching the steering link.
    it has to be an 8lug to 8 adaptor in 1-2" wide.
    does anyone knows where can I find it ?
    ThanX
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Re: 8 lugs adaptor \\ spacer
    I don't believe that running a spacer on the front wheels is reccomended. Most people have the hummer rims recentered unless they are running dually hubs /forums/images/graemlins/waytogo.gif
  3. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I don't think its a problem. I've heard of people running them.
    I get all my spacers from these guys: Performance Wheel & Tire
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That would be dangerous.
  5. arik2
    May 25, 2003
    9
    Hi,
    I'm checking currently with the Performance Wheels & Tire and it seems that there are no spacer to 1986 K25-30 with 8 lugs but there is a spacer for a 1996 k2500 and I believe that the pattern are the same (though im not sure regards the competability to the brakes etc.), and anyway, the truck is not my DD.
  6. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    There is. You have to call 'em. I'm running a set of 1.5" spacers on my 14b f/f. They make them themselves, so they can build them to your specs. People run spacers up front all the time. Safety issues only arrise based on how large of a spacer you run and how it is mounted. The guys at Performance Wheel would probably be the best source on weather or not you should run spacers up front and if so what your size limitations should be. Give 'em a call. /forums/images/graemlins/waytogo.gif
  7. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I've found this place- 8 lug to 8 lug spacers for 109 plus s&h. www.truckn-store.com 800-682-trux T6061 CNC Billet
  8. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    I´m running 1,5 inch spacers on all 4 wheels on my M1008 with Hummer rims and have no troubles with them.
  9. arik2
    May 25, 2003
    9
    Thanx a lot guys,
    I will probably buy them within a week and a half.
    Arik
