8-lugs for 15 inch tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by EDdaTREE, Jun 7, 2000.
  1. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Got a buddy looking for 8-lug 15 inch wheels to run gumbo's on his 3/4 ton axles....anyone know a company that makes these?
  2. Grim-Reaper
    7,385
    Atlanta
    About the only rim you will find is a wagon wheel for about $35-45 each. Now here is the deal...if your bud is running a 10 or 44 front then with some quality grinder time yes you can get 15 inch rims on the truck with some offset but if your bud is running a D60 front then I don't think the 15's will fit if he plans on running front brakes.
    Diging it in the dirt with my K5's
    Grim-Reaper
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I just ordered a set of white 8 spokes in a 15x10 eight lug from Discount Tire in dallas. Their # is (915)-947-8977. They told me I would have to grind the calipers but that's no big deal. The wheels are made by unique and are a build to order wheel, which means no refunds. If they don't fit you still have to keep em. If you call ask for Branden, he's the guy I talked to and he's got a 4x4 background which means he won't say no immediately when you ask for an 8 lug in a 15x10.
    BIGJ
  4. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    Bart wheel and Eaton both make 8 lug 15" wheels
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    American Racing also makes 8-lug 15-inch wheels. The main limitation you'll find is that all the 8-lug 15-inch wheels out there are steel only. Due to the thickness of aluminum wheels there would be no clearance for the brake calipers.
    8-lug 16-inch wheels fit with no grinding, but there isn't a very good tire selection available yet for them.
    <font color=blue>http://ThunderTruck.ColoradoK5.com</font color=blue>
  6. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    I may be mistaken, but I thought that a d44 out of a 1/2 ton and a 3/4 ton were the same other than the obvious # of wheel studs. If this is true then why would you even need to grind the caliper, they're the same?
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The rotors appear to be larger in diameter. I've got an 8-lug 15x10 American Racing white spoke wheel that I bought to test-fit on my truck. It definitely doesn't fit my 8-lug Dana 44 front axle. [​IMG] The caliper bracket is in the way more than the caliper itself.
    Clearance isn't much of a problem on the rear 14-bolt FF, but it has been converted to disc brakes using the TSM brackets and '76 Caddy Eldorado rear calipers.
