8" of lift with stock rear springs
Discussion in 'The Garage' started by MudFlap, Mar 17, 2003.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    8\" of lift with stock rear springs
    What are my options on getting 8" of lift in the rear with my stock springs. I will do a shackle flip, this will give me 4".
    I want to move the axle backwards about an 1.5". So I was thinking about using zerorates, but how could I get the other three inches? Should I use a longer shackle? How much longer can I go? I am going to reweld my perches so pinion angle is not a concern.
    Or should I use 4" blocks and drill my spring perches? Or longer shackles and shorter blocks? Or anything else that I have not thought of.
    Thanks,
    Trey
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Re: 8\" of lift with stock rear springs
    What tires are you planning on fitting? You could probably get away with alot less if you trim. Unless you're going with like 44's or something.
  3. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    40's. I will trim if I need to but nothing to major. I have a 2" body lift too. Would 7" be better than 8"?
    Trey
  4. RustBuket
    Feb 21, 2003
    1,618
    I'm just the kind of guy that would trim the heck out of my fenders b4 spending more money on making my rig tippier. I guess you gain some ground clearance under the frame.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    www.truckinsuspension.com makes a hanger lift kit that uses stock springs, I think. 6" and 9" I think. Expensive though, lot cheaper to just buy new springs and all.
  6. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    the zero rates, moving the axle back 1 1/2" will really only move your axle bake about a 1/2", I just did a flip and moved my axle back 1", it looks to be in stock location with the flip, I think because when you do the flip it swivel the axle closer to the front?? blocks are ano no, I've broken too many springs with blocks, I asume you do plan to run bigger tires with lower gears, 8" and all, so if you have blocks get use to snaping springs, just do the zero rate and fab a little longer shackle, also plan to run a cv joint, if you want it right
  7. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    How about a echobit flip with a zero rates. That will net you arond 7 inches.. Get6" front springs with zero rates also, then with your 2 inch body you'll have 9 inches of lift. With a little trimming you can fit 40's.
  8. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Go 7"... 4" shackle, ORD offset zerorates, and 2 or 2.5" blocks...
    Chris
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Blocks AND zero rates? That's akin to stacked blocks, I really don't think that it would be too safe. I really don't see an ideal way to get that much lift with stock springs. You could do an add-a leaf for a couple inches plus a shackle flip with a longer shackle to get about 7", but it's really a pretty half-ass way to do it. </font>
  10. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    8" of lift to fit 40s? is this a jeep we're talking about??! gods gift to the fullsize chevy is the ability to run huge meats with a small lift... take advantage!!! /forums/images/graemlins/grin.gif
    j
  11. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    what about 7" of lift with 6" springs and zerorates in the front. A shackle flip and zerorates in the rear, with 4" longer shackles? Is that too long of a shackle?
  12. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    with the money you are going to spend on flip's, zero rates, and shipping, add a little more and get 8" spring's.
    then you don't have to worry about it.
  13. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    are you talking about 8" springs for the rear? If so, I was trying to stay away from springs in the rear, so it would still be somewhat of a soft ride and fairly flexy too. I also think that I might go to f150 springs in the rear sometime in the future.
    Trey
  14. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Getting up to 8" on stock springs can be done. I've had people run my flip to get between 5.5" - 6" and a tapered 2" offset zero rate to correct driveline geometry as well as retun the wheelbase back to stock from the flip. This nets 8", give or take about 1/2" depending on the specific components on your application. With stock springs, the 2" will promote a bit of wrap, on 57's it would promote a lot of wrap. If your planning on running 57's in the future anyhow, youre probably already thinking about adding some antiwrap control which would eliminate the downfall of the 2" zero rate and allow you to keep the stock springs or run 57's.
  15. captain chaos
    Mar 29, 2002
    413
    yes i was talking about the rear.
    8" skyjacker soft rides ride just as good as stock springs. ( from what rode in)
    dave
  16. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    have you SEEN an 8 inch lift spring for a chevy? holy hell! there is no way you are going to get a spring with that much arch and that few leaves to ride nice. my brother has 8 inch springs on his truck and those things are shaped liek my friggin u-bolts. go with a 4" flip and 2 or 4 inch springs, depending on what you do in the front.
    -Scott
  17. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    All you gotta do is bend the spring clamps out like I did. It helps remove the freight from the train. /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
  18. captain chaos
    Mar 29, 2002
    413
    SEEN, i've RIDEN on 8" lift spring's.
    rode better than stock spring's.
    dave
  19. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    What do you mean "bend the springs clamps out"?
    Trey
  20. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    you can run a shackle flip and 4" blocks. Some blocks have offset built into them. I"m currently running that exact same setup, except with 56" springs turned backwards.
