8" spings + zero rate
Discussion in 'The Garage' started by dheavychevy38, Apr 30, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    If i run my 8 inch springs in the front with a zerorate to move the axle will i have to do much trimming to run my 38's?
    Will i have to lengthen my front drive shaft?
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    nope, might need slight to clear at full compression
    you will at least need a shaft with a longer slip, probably longer overall as well
