8" springs in rear... or add-a-leaf on 6" springs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, Jul 5, 2002.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    8\" springs in rear... or add-a-leaf on 6\" springs?
    as soon as the bank account grows, the '81 is gettin 6" springs in front. i know the fiberglass top makes the rear sag a bit. should i just go for the all 6" spring lift and install an add-a-leaf? or should i just go with a pair of 8"springs in the rear? if add-a-leaf is the way to go, do you install the leaf while the spring is on the vehicle? or just out of hte box? i'm a "suspension greenhorn", so please bare with me.any help is appreciated.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: 8\" springs in rear... or add-a-leaf on 6\" springs?
    I'd skip the add a leaf. I have one and, if money permitted, I'd have a new leaf pack instead.
    If you are going to do the add a leaf, you can install it on or off the vehicle. Use C-Clamps x 2 to hold the rest of the spring pack together, remove the center pin, install the add a leaf and a new center pin and off you go.
    -- Mike
