8" suspension 3" body and cut fenders??
Discussion in 'The Garage' started by MUD JUNKIE, Jan 15, 2003.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    8\" suspension 3\" body and cut fenders??
    what size tire do you think would fit on a 79'chevy 3/4 pickup? I dont have the 8 incher yet but I have the body lift and a 4" suspension lift on it now.I cut about 6" away from the fenders also.what would the front axle angle look like? its a dana 44 for the time being,until I get my 60.
    /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: 8\" suspension 3\" body and cut fenders??
    Well, with that kind of lift and trimming, 33's should fit (LOL) I'd guess some 42's would work.
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have 7" susp and 3" body with cut fenders and I could easily run 44's..maybe even 48's. My front angle is bad, I need to shim it 6 degrees
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have a 6" lift, Dana 60, 3" body lift, and slightly longer heavy duty shackles. I have also moved the axle forward 1.5"'s. I run 39.5"s and have plenty of clearance. Looks like I could run 42"s and still clear in the rocks. 44"s for the mud no problem.
  5. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I have the 8" and 3" and the front moved forward 1.5" and the rear back 1.5" and run 39.5"s with no cutting so with the cutting you have 44's would fit.
  6. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I run 4"+1+ body lift and 39.5's...it's been trimmed slightly here and there. /forums/images/graemlins/thumb.gif
    Rene
  7. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    how do you move the axles forward or backwards? what does this do??
  8. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    There are a few ways to move the diff's forwards or backwards. I chose to drill a second hole in my perches 1.25" back from center. When I mounted it up to the springs it sat 1.25" forwards from the stock location. I had to drill a second hole in the spring plates too...
    A-tron builds zero-rate blocks with offset holes too. I beleive you can also get them at whatever angle you like as well as flat.
    The reason I moved my D60 forwards was to gain clearance between the tire and the firewall/floor area when the tire was stuffed. My goal was to run as large a tire as possible with as little lift as possible.
    Rene
  9. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I did exactly the same thing as TrustyK5. Its a free mod and it makes a big difference. I wish that I had done this before the body lift went on. I might have been ok.
  10. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    i run a 6 in spring and the typical trimming and run 38.5 boggers no rubbing, your description sounds like a combo for 44"s in mud and 42"s for flex type terrain!!! JMO!!!!! /forums/images/graemlins/usaflag.gif
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I always seems to slowly get bigger over time. /forums/images/graemlins/grin.gif
  12. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I've heard that's normal for a man of your age... /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Rene
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    I wasnt talking about my tummy!
