8 to 6 lug adaptor
Discussion in 'The Garage' started by durantk5, Apr 6, 2005.
  1. durantk5
    durantk5 Registered Member
    Mar 1, 2005
    50
    Greensboro, NC
    Where can i find an 8 to 6 lug adapter for a rear 14 bolt ff?
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Buy new wheels with 8 lugs. Like discount tire, or belle tire...etc.
  3. durantk5
    Mar 1, 2005
    50
    Greensboro, NC
    but when i rotate the tires i dont want to have to take the tires off the 6 lug rims and put them on the 8 lugs and vise versa
  4. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    you can change the front to 8 lug for under $200
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    This has been discussed many times before. It can be done (and has), but it requires custom machining of a lot of the14bff parts and usually ends up costing more than the front 8-lug conversion and new 8-lug wheels.
    There is no bolt-on wheel adapter for this. I looked for somebody to make them for me and couldn't find a company that would. It would have to be very thick and it's strength would be questionable since some of the bolt holes have to be very close to each other. Plus, you 6-lug rims would have to have the center hole enlarged out pretty much into the lug nut area, which is obviously not good.
    Another option is to use a 14b s/f in the rear since they can be converted to 6-lug easier. Of course they aren't as strong.
  6. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    A member on here, MrBill, had a new set of adapters we were trying to sell for him at the swap meet. He still has them as far as I know.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Forget adapters, drill the hubs to 6 lug. Theres a member here who does it to the hubs.
  8. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    There is a member around here (TonyP) that custom machines these.
    You can also find adaptors at:
    wheel adaptors
    Here's a pic of a redrilled hub and a pic of an adaptor:
