8 vs 12 bolt hummer rims
Discussion in 'The Garage' started by 90BCk5, Jun 2, 2005.
  1. 90BCk5
    90BCk5 1/2 ton status
    Apr 8, 2005
    278
    British Columbia
    12's are better, are they not? i found a guy in canada who would sell me 5- 8 bolts but for too much and they arent 12 bolt.... so my Q is--->anyone know of a (reputable) business that sells the military version? im not having any luck w/ this and id like to get this truck on the road before the white stuff falls again! thanks :D
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I don't really know why anyone would really want (or need) the 12bolt version. The later 12bolt rims do use thicker metal; they standardized the rim to the HD version after the M1114 Up-Armored HMMWV came out. The M1114 is one heavy MoFo! But I've never seen a bent rim (either style) that wasn't involved in a crash. Guess you could bend one give enough weight and abuse.... :D
    The 8bolt is plentyful 'cause most (Army) units have ditched the bias ply Wranglers for the radial. The radial uses a rubber funflat/bead lock, as opposed to the bias magnesium runflat/bead lock. I would use one of those PVC beadlock for a play truck (and loose all that unsprung weight).
    * The best thing about the 8bolt is the rim doesn't CRUSH the O-ring like the 12bolt rim does. You can actually re-use the O-ring for the 8bolt; the 12bolt o-ring looks like a bead of RTV when u take it apart. 12bolt rim is prone to leak air too; assemble 20+ rims at a shot and you're garanteed to have a couple of leakers ! :rolleyes:
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    interesting post....
    The only thing I knew was that 8 bolt for bias and 12 bolt for radial... guess you could use either on either rim... but not sure...
  4. 90BCk5
    Apr 8, 2005
    278
    British Columbia
    8 bolt for bias? damn i thought it was the other way around.... are those rims 9' wide? what would be the widest tire i would want to run on a 8 bolt hummer rim? thanks guys ! :D
  5. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    The 8 bolt hummer rim was used to run a bias tire at a lower pressure. The 12 bolt rim was used to run the radial tire at a higher pressure. As for the o-ring issue that was mentioned. I run a 12 bolt setup and have had zero airleak issues and have disassembled and reassembled the rims several times with no distortion of the o-ring. The hummer rim, be it 8 or 12 bolt are both a 8.25" wide rim with a 7 inch back spacing. The 8 bolt and the 12 bolt have different max air pressure ratings as well as different max weight ratings. I hope this helps as far as information goes. As for who sells them, I can't say. I have been looking for extras to have, but have had very little luck.
  6. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    Here is a link to all the info that I have regarding hummer rims. Hummer Info
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    I have not dealt with them personally so I am only saying what I have heard..
    I would not deal with them as people have had ALOT of bad experiences with them..... sorry...
    Jeff
  9. 90BCk5
    Apr 8, 2005
    278
    British Columbia
    thanks for all the info guys, i found 5- 8 bolt rims w/ mag runflats and all hardware in canada, im going to be running 38x16 swampers on them and just wanted a few opinions as to which would be better suited for me...
    thanks again
  10. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    We did this every couple of weeks for the past year, so I stand by what I said. :rolleyes: As far as crushing the O-ring, there maybe a difference between the earlier 12bolt and the later HD 12bolt rim. We left all of equipment in Iraq, so I don't have any HMMWVs in the yard now. 'Did really feel like breaking down a rim just for a picture anyway ;)
